Old 21st May 2020, 05:59 PM
Carladams Carladams is offline
Default Rns d in early D2
So coming to the last of my mods over lockdown , big thanks on the advice re retro fit solar roof which is great but heavy !
Next is to instal The Nav plus , I was lucky enough to acquire an early pre facelift centre console so just trial fitted the unit today as I had it on the shelf for years ( thanks A8 parts ) so all came on entered the code and got this
Any ideas , I know the code is correct as it is written on the unit as it was supplied
Thanks in advance
ID:	23361   Click image for larger version
Old 21st May 2020, 06:02 PM
Does that mean that the "safe" wire isn't connected in the wiring loom?
Edit: Probably, as stated in this thread: https://www.audiforum.us/threads/cod...i-system.1015/
Can't recall the details but there's a wire that needs a constant +12v (I think) that is usually labelled "SAFE" in diagrams.
Old 21st May 2020, 06:56 PM
Safe wire ? What would that look like ? It’s a very early d2 which has its delta with CD player as standard ( although xcarlinked to iphone etc at moment )
Old 21st May 2020, 07:00 PM
Woops sorry didn’t see the link , I’ll try that in morning , although after reading the thread Ian has done on RNS E I may do that instead but guess I’ll need the safe wire for that too ! Thanks again
Old 21st May 2020, 09:58 PM
Just Google a wiring diagram for RNS-D and you'll see SAFE on a pin on one of the 8-pin connectors. Just link it to the permanent +12v wire.
Or look on the RNS-D itself, they usually have a label with the plug/pin layout...…..
