Old 5th January 2010, 10:46 AM
CliveH's Avatar
CliveH CliveH is offline
Default RNS-D locked up
Whilst fixing the wiper motor problem, I managed to drain the battery!
All charged up again and working fine but to my embarrassment, I have then managed to lock up the Satnav/radio unit (as I tried to input the code from memory ).
Just wondering if there is another way of unlocking it (other than removing the battery for an hour or something?) such as Vagcom or some secret combination of key presses on the unit?
The reason that I appear to be so lazy is that my battery compartment is covered by the luxury of the 10 DVD changer and Playstation cradle.
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs
Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten
Old 5th January 2010, 11:17 AM
If you '**** up' the PIN entry on any of the D2 audio units and end up in 'safe' mode then you just need to the leave the unit on for an hour and it will reset. You might need to have the ignition on too to make sure the unit doesnt do its 15 minute power save thing....
Disconnecting the battery will do nothing, other than waste an hour of your time fighting with the RSE kit
I know of no known vagcom reset method - This is designed so that you can only try 3 times an hour, with 10,000 combinations, it makes 'nicking it and guessing it' a bit unfeasible.
Old 5th January 2010, 11:34 AM
CliveH's Avatar
aha! there's where I'm going wrong (again, trying to do it blind without the manual) - so it's leave it on for an hour, and not to disconnect the battery for an hour - doh!!
thanks Ian, just hope I dont drain the battery again in the process...
