Old 7th September 2017, 06:35 PM
I had 20l delivered today, this was the cheapest I could find, and that was delivered to my door
Yeah I have bought from them before, they are a reputable (as far as any dealer can be) multi franchise dealer in Scotland
Audi S8 2002, Black (even the chrome bits)
Audi RS6 Avant 2008, Daytona Grey
Maserati Granturismo 2008, Metallic Nero Carbonio
Old 8th September 2017, 12:13 PM
This looks useful too, its for USA I couldn't find the UK/Europe bulletin. Must be available somewhere.
https://www.audiusa.com/content/dam/...e-Bulletin.pdf
Old 8th September 2017, 12:17 PM
Interesting thread
https://www.bobistheoilguy.com/forum...or_am_I_wrong?
Name:	VW oil spec.png
Old 8th September 2017, 07:35 PM
This diagram from the oilspecifiation.org site was quite good i thought.
Old 8th September 2017, 09:02 PM
Simonbartlett Simonbartlett is offline
Yes and one of the few sources that correctly says the R5 2.5tdi needs 506.01, its unusual for anyone to get that correct.
Owner of a 2008 A8 3.0tdi SE
Old 8th September 2017, 09:50 PM
I will just add a couple of my thoughts:
1. About engine flush. I don't think it is needed for engine and oil made in last 30 years which has been regularly serviced and not overheated. Flushes were designed to dissolve burned on deposits from old mineral oils. Modern oils have additives that take care of it and should not be a problem for modern synthetic oils if they have been changed to schedule and engine have not been overheated causing oil to burn on. In the rare cases if engine oil is too diluted with unburned fuel they may even cause damage to engine by diluting oil even further. It's an unlikely scenario but on diesels with DPF being driven short distances oil contamination with unburned diesel can reach over 40% between oil changes. In most cases flush will not do any good or any harm, just a waste of money.
2. I like the idea of 2 oil changes but I do not think it is necessary, the oils are designed to have up to 40% dilution and if you change them at intended intervals or sooner you will be OK apart from some rare cases on diesels with DPF which are driven short distances.
3.Dealer oils like Quantum are designed to be good enough for most of their cars most of the time but they are not the best. So certainly there is a room for improvement.
4. Many of modern oils are designed to meet emissions and fuel efficiency, they meet minimum requirements for engine protection but they are not necessarily the best. For the England you do not need 0Wxx or 5Wxx oils, it's just that they are thinner so introduce less resistance and require less energy so are better at fuel consumption and emission but are not necessarily good for engine. That being said modern engines are made good enough to make it through warranty period even with lesser oils. I don't think manufacturers are particularly interested in what happens after 100k miles.
Just to end this I think Quantum Longlife III is a good oil for every day driving and occasional push but should not be used for 18k miles which manufacturer allows but changed at least once per year.
If you take money out of equation 10W60 oil should be better if you drive hard and everything else is equal.
You may also consider molybdenum disulfide powder additive to the oil which will reduce friction, wear and temperature. Don't buy the liquid ones as they will just dilute the oil, get the powder.
Old 8th September 2017, 09:53 PM
Slightly confused now, this suggests 507 is for Diesel, whilst my handbook for the RS6 suggests 507 is the correct spec, I know it supersedes previous 50* for the S8, so hence confusion from a simple country boy in a very dreich Scotland..
Old 8th September 2017, 10:01 PM
Just to make it simple:
You can use diesel oil in petrol engine most of the time. If you want to use petrol oil in diesel there mo more research to be done.
In the old days the difference was that diesel oils had more sulphur neutralising additives, later they had more high pressure additives for PD and less ash to preserve DPF's
