Old 11th April 2019, 03:06 AM
roberto's Avatar
roberto roberto is offline
Default Rear brake upgrade anybody done this ? D3 3.0tdi
i have S8/W12 front brakes and i want to upgrade the rear ones
question?
do i need everything say Discs/pads/calipers/caliper carriers
or can i use my own calipers?
using S8/W12 rear discs and caliper carriers?
ps. whats the difference in size?
cheers all
Old 11th April 2019, 06:53 AM
There are three sizes of rear disc, ignoring ceramics
280x22
310x22
335x22
The caliper is the same across all these, as is the splash plate, so all you need is the discs and the caliper carriers.
For 335x22, carriers are 3D0615425A (left) and 3D0615426 (right). I think those are Phaeton numbers, possibly Bentley, so they may be straightforward to find.
The D2 is the same - the only difference between A8 and S8 rears is the caliper carrier and disc itself.
Old 11th April 2019, 12:15 PM
roberto's Avatar
Thankyou so much, really appreciate that
Old 11th April 2019, 02:37 PM
roberto's Avatar
280x22
310x22
335x22
Hi, sorry tps are saying they are the part numbers for the 280x22 discs which are standard on my 3.0 tdi
cheers
Old 11th April 2019, 03:28 PM
This is what my Etka shows:
Same numbers for all versions but different suffixes for different sizes. Also note that the 280 is not handed but the 310 and 335 are. Not sure why that would be. The rear hub is the same for all versions.
ID:	21347   Click image for larger version
ID:	21348   Click image for larger version
Old 11th April 2019, 03:51 PM
roberto's Avatar
ok, they told me part numbers have changed?
now got .. 4EO 615 426 A .&. 4EO 615 425 A = Caliper carriers
these are for 335MM DISCS
S8 2008
nightmare
i wonder if D4 rear brakes fit ?
Old 11th April 2019, 04:10 PM
That's not unexpected - there are often supersessions and my Etka is a bit out of date.
The theory is still sound that discs and carriers from an S8 will fit an A8. Hubs are the same, splash plates are the same, calipers are the same.
Old 8th May 2019, 02:50 PM
NightOwl NightOwl is offline
Late on reply, but I've done this on my D3 3.0TDI and you need as mentioned discs and carriers, and maybe the outer brake hose. I was able to squeeze the caliper over the disc but it was tight with the larger disc.
Should be a thread I made here somewhere from few years back.
2006 Audi A8 3.0 TDI Quattro Sport
A8 W12/S8 Brakes front and rear (385mm/335mm)
Focal and JBL speakers, Helix amps
S8 anti-roll bars front and rear
Complete rear LED taillight
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
