Old 16th October 2021, 07:15 PM
Ronin Ronin is offline
Default Oil cooler hose dangerously close to AC compressor
As in the pictures... I reckon it lost its shape due to age or something, surely audi wouldn't design it like this.
Am I right in thinking that 078 121 058 AH is the replacement (luckily still available) hose
Name:	WhatsApp Image 2021-10-16 at 19.19.24.jpeg
ID:	27315   Click image for larger version
Name:	WhatsApp Image 2021-10-16 at 19.19.36.jpeg
Old 16th October 2021, 07:53 PM
Hope that's right.. exactly the same issue on my A8. Neat little trick by a 'mechanic' was to keep it away from the pulley by using a zip tie!
Paul
Gosport UK
________________________
Audi S8 2002 FE Avus Silver / Extended Red Leather.
Daily Driver: BMW 3 series GT - Just more practical for my camping trips!
Old 17th October 2021, 08:46 PM
I think I'll be doing the same until i can get them from audi tradition in germany, i can let you know and order one for you too?
Old 17th October 2021, 09:59 PM
When I did Big Red this hose was soaked in oil from leaking cam cover gaskets, so it was swollen and distorted. I couldn't get one at the time (Tradition wasn't an option then) so I made my own which fits rather better.
Maybe you can rotate it around the top fitting so it has a bit more clearance?
Old 17th October 2021, 10:23 PM
If you can get one then I will take one too.. just PM the value and I will send.
The hose on mine is pretty fragile, there are witness marks where the pulley has eaten slightly into the side. I must admit I only noticed this when working on another item underside and wondering what the zip tie was doing there. I would prefer to leave it alone until a replacement can be sourced. Assume then will have to follow your video on venting the cooling system afterwards?
Paul
Gosport UK
Old 18th October 2021, 08:17 AM
Yeah it'll need the vacuum filling method. Happy to lend out the tool to forum members You'll need an air compressor to run it.
