Old 19th March 2021, 12:37 PM
roberto's Avatar
roberto roberto is offline
Default Ceramic Polish / Coating etc
has anybody got any opinions on ceramic polish / clay barring etc
looks like a mine field on ceramic stuff
Old 19th March 2021, 01:54 PM
Halfords sell a clay glove which I use after washing and before polishing. It seems to remove minor contamination quite well and leaves a smooth paint finish to apply polish to.
Old 19th March 2021, 02:02 PM
If you're considering it, I'd get it professionally applied with a guarantee (which usually involves getting them back to inspect and top up on an annual basis)
Our Golf had a new car paint correction and ceramic coating by a GTechniq dealer, which is warranted to the purchaser for 7 years, and it's still doing something even now the car is 6 years old. It's not transferable, so I've not had the inspection/top up as we're the 2nd owners, but it does make the car easier to keep clean.
The important thing with ceramic coating is that the surface it's applied to needs to be spotless, and ideally you want it as blemish free as possible otherwise you're just covering imperfections. Ceramics have got easier to apply, but I'd certainly want it doing indoors in a controlled environment (temperature and humidity) so it cures properly.
Given what you've spent on the RS I would defo do it
Old 19th March 2021, 02:43 PM
I would agree. If ceramic coatings go wrong, on a car like that...
I would suggest looking up a local Professional Valeters and Detailers member - they are all insured and often manufacturer-trained and / or accredited so you know the car is in safe hands.
The PVD directory can be found here
The members with green dots are the PVD-approved ones
Old 19th March 2021, 03:44 PM
Yep, and some of the more common product suppliers also run a list of recommended regional suppliers that've been trained in use of the products, so worth a cross-reference
Old 19th March 2021, 04:25 PM
I'd wholly recommend ceramic. It costs a few hundred quid, but lasts at least three years, and makes washing the car a whole lot quicker and easier, as well as protecting the car better than any polish does.
I think I've got CQuartz Pro on mine, but I can't remember to be honest, but definitely worth getting a pro to do it, properly.
Old 20th March 2021, 09:39 AM
roberto's Avatar
Default cheers guys
im doing some research as sujested
souns like a dealer is the best option
Old 20th March 2021, 12:45 PM
It is best done by a pro.
But I have done my own for a few years now and always been well pleased with the result. I love the smoothness of the finish. Really hard work and I suppose I'm getting too old for it. Then it's certainly not an annual task.
Well worth the expense.
Old 20th March 2021, 05:11 PM
Steer clear of a Dealer, it's a DETAILER you want
Old 20th March 2021, 11:44 PM
I'd be very cautious using a clay glove or any similar abrasive on a regular basis. It is easy to wear through the top coat, especially on raised edges. I know, I've done it. Pre Audi days thankfully.
