Old 7th November 2015, 10:15 AM
Burnzybubbles's Avatar
Talking from experience there mate?
I can neither confirm or deny your allegations
Old 10th November 2015, 08:50 PM
neeldub neeldub is offline
So I did some research today into the wiring of the wing mirrors. Turns out that the wiring and connector for the Side assist mirror cap lights are present. The blue/yellow wiring runs from the wing mirror harness to the 4 pin connector in the door harness. However from there all the way to the rear of the car will need to be custom fit.
A few snaps...
Part number of my fitted wing mirror
I then had a look behind the door trim..
From door harness to the rest of the car, the blue/yellow wire isn't present. According to ELSAWIN, from this point the wiring changes colour to Purple/Blue.
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 18th November 2015, 06:45 PM
If anyone is looking at doing this, I spotted these S8 mirror caps with side assist cutouts:
http://www.ebay.co.uk/itm/Audi-Chrom...8AAOSwKIpWAcB8
Old 19th November 2015, 09:04 AM
Not genuine though
Previously:
Currently:
Old 20th November 2015, 11:36 AM
Conquistador's Avatar
For Lane Assist retrofit wouldn't you also need the different indicator stalk, windscreen and windscreen camera/sensor?
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 20th November 2015, 05:45 PM
Nope as I'm looking to do Audi Side Assist retrofit ( Lane Change Assist). In elsawin Side assist is referred to as Lane Change Assist.
Previously:
Currently:
Old 18th August 2016, 10:10 PM
Originally Posted by neeldub View Post
Wiring Diagrams attached...
Hey guys i am in the process of retrofitting this.. All is set but i'm having a minor issue with the wiring.
Can someone explain the wiring on the last page for me please.
What happens at connection B565 in the main wiring harness... Do the wires from both doors join here to connect to pin T10v/4 to the bumper connection?
I've got the following error message at the moment as a result of this..
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0020
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0010101
Shop #: WSC 31414 790 00001
VCID: 2E54842BB96DB53202-807A
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H01 X080
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F21.11.0700H010003C910145ÿ
Subsystem 4 - Serial number: 910145ÿ
3 Faults Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 227
Mileage: 123056 km
Time Indication: 0
Date: 2016.08.18
Time: 17:55:32
02854 - Warning Lamp for Lane Change Assistance (in right exterior mirror) (K234)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 227
Mileage: 123056 km
Time Indication: 0
Date: 2016.08.18
Time: 18:01:02
02001 - Data-Bus Automatic Distance Regulation
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 12
Mileage: 0 km
Time Indication: 0
Date: 2008.01.01
Time: 00:00:00
Any ideas?
Thanks
Previously:
Currently:
Old 23rd October 2016, 10:26 PM
Hey guys, quick question to owners who have side assist fitted from the factory. Can you kindly share the coding information from your modules so i can configure mine accordingly please.. many thanks
Previously:
Currently:
Old 24th October 2016, 02:04 PM
Turbo Tony's Avatar
Part No SW: 4L0 910 566 B HW: 4L0 907 566 A
Component: J0769_SWA_MasterH10 0130
Revision: 00H10000 Serial number: 6PZ 009 014-00
Coding: 0001109
Shop #: WSC 02313 785 00200
VCID: 2D12C920B4CC3B56E5-8079
Subsystem 1 - Part No: 4L0 910 568 B
Component: J0770_SWA_Slave_H08 0130
Subsystem 2 - Serial number: 6PZ 009 014-20
Subsystem 3 - Serial number: 3F29.03.0800H0800000010155ÿ
Subsystem 4 - Serial number: 010155ÿ
No fault code found.
Address 5C: Lane Maintain. Labels: None
Part No SW: 4E0 910 217 C HW: 4E0 907 217 C
Component: J759 LDW H07 0070
Revision: 00H07018 Serial number: 80020840800035
Coding: 0011202
VCID: 200C2014F31EE63E5E-8075
Hope this helps
Storytellers Villa Orlando
2008 Audi S8
Old 25th October 2016, 10:36 PM
Coding: 0001109
Coding: 0011202
Hope this helps
Thank you buddy.. much much appreciated
Previously:
Currently:
