Old 19th May 2021, 07:18 PM
I've not seen it on a D2 before, but thats the exact same noise my A6 1.9TDI makes with a locked-up alternator pulley...
Old 19th May 2021, 07:49 PM
Ronin Ronin is offline
Talking
In that case I'm gonna have to find an alternator or a brand new rotor with extra long thread to accommodate the clutch pulley. I destroyed the one I had trying to get the pulley out with a breaker bar. In my case the clutch spun freely in both directions
Old 29th May 2021, 08:31 PM
OK, so it turns out that the 2.8 Alternator with freewheel pulley has a rotor thats longer to accomodate said pulley.
Part number for the rotors can be found from 2 different manufacturers:
HC-Cargo Art. Nr: 138177
https://as-pl.com/en/p/AR0066
A rotor and a freewheel pulley is all thats needed to convert an A8 alternator into 2.8 alternator, there is no specific part number for a 2.8 alternator with freewheel clutch.
Old 24th January 2022, 05:13 PM
If you can share the links for the seal that would be great. I have just ordered the VDO pump. Thanks again
Found the o-ring info:
"69x2.5mm for the top one under the cap, 112x2.0 for the larger one in the pump body." - credit to Mikki.
Hi Ronin, where did you source the O rings? I have the same issue and going down the route of a new pump
Paul
Gosport UK
________________________
Audi S8 2002 FE Avus Silver / Extended Red Leather.
Daily Driver: BMW 3 series GT - Just more practical for my camping trips!
Old 25th January 2022, 07:20 AM
https://simplybearings.co.uk/shop/
