Old 20th May 2013, 05:28 PM
sloss's Avatar
sloss sloss is offline
Default VCDS Security Code
I'm trying to re-code the parts for the headlamp washers where you can reduce the wash cycles:
[09 – Cent. Elect.]
[Security Access - 16] (Enter code presented by program)
[Adaptation - 10] -> Channel 26 Change to desired number e.g. 10
However I can't get past the Security Access as no Code is presented.
Also fancy the needle sweep:
[17 - Instruments]
[Coding - 07] -> [Long Coding Helper] -> Byte 1 Bit -> 0 Change 0 to 1
Or Check the box for "Gauge Test/Needle Sweep active"
I don't see the Byte type info anywhere ie I don't get the 'Long Coding Helper' anywhere else either.
When I Recoded to tell the car it has LED DRLs it 'offered' a Security Code no problem.
I have a full legit Gendan VCDS doofer and both the Normal Software and the BETA Version to see if that offered any more help.
Any ideas folks
Old 20th May 2013, 09:39 PM
Way over my head mate sorry. Only time i've had needle sweep is in the output tests for the instruments but that is for D2
Old 20th May 2013, 10:26 PM
the needle sweep isnt on all cars my 2005 doesnt allow it
i will try to take a look at the other one tommorow to see what mine does
Old 21st May 2013, 06:03 AM
sloss's Avatar
Guys, it's not so much the particular re-codes that I want to do, it's the fact VCDS doesn't show me the 'Long Code Helper' or offer a Security Code.
2008 3.0 TDi is the vehicle.
