Old 8th March 2012, 05:44 PM
chewy chewy is offline
Default B&O tweeter
Not used the car for a couple of weeks, on start up i noticed the tweeters did not pop up. I restarted the engine and only the passenger tweeter popped up. Have done a few stop start journeys and the drivers side tweeter has not popped up. Is there anyway to check ie with vagcom? anyone with any experience of this?
TIA
Old 8th March 2012, 09:48 PM
I'd try wibbeling the plate at the top of the tweeter about, perhaps its a bit stuck.
Also have you turned off the system by holding the on/off/volume knob down for a second or so, and then back on by giving said knob a quick jab
Old 10th March 2012, 01:50 PM
Thanks for advice tonup. Have tried turning the system on and off a few times but to no avail. Can't feel/hear anything when turning system on/off. Anyone know how to take the tweeter out? does the top black cover plate prise off?
Stumped as it was working perfectly a couple of weeks back.
Old 10th March 2012, 01:55 PM
sarg sarg is offline
if I had a pound for everytime I've heard, or said, that phrase
2019 BMW M5 (my daily driver)
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 21st April 2012, 04:21 PM
A8_Tony's Avatar
A8_Tony A8_Tony is offline
Chewy, did you get to the bottom of this?
I've just had an issue where I've got no sound coming out of my system and the tweeters didn't pop up
A8OC Founder
The A8 Owners Club here
Old 21st April 2012, 04:31 PM
MAM MAM is offline
I am also having problems with my B&O system. I did look through the technical PDF on the system which did show that if a tweeter was unable to raise, it would reset itself and raise when the obstruction is cleared and the system restarted.
Mine has problems with Bass with rattling speakers. I may try to beg Audi to consider that as the car was sent to reviewers that the system was used and abused which has shortened the life of it.
None of my other B&O equipment has died this early in its life, so I am quite disappointed in its longevity in my car.
Deep Green 2006 '56' A8 4.2 SE, B&O & Exclusive Interior
Extended Aluminium, Oak Sepia Wooden Trim, Extended Leather
Green Exclusive Dual Colour, Heated Comfort Leather Interior
Green Alcantara Headlining, Pillars, Rear Shelf, Door Inserts
Green Trimmed Mats, Seatbelts, Steering Wheel, Centre Armrests
DAB, Freeview, ACC, 4-Zone Climate, Soft Close, Electric Blinds
