Old 7th January 2020, 12:20 PM
classexa classexa is offline
Default Need help with ABS problem. 4.2 -03
Hi there. Recently bought this car and boy, what have I gotten myself into. lol. Anyway, have a bunch fault codes but the reason for this post is the red brake warning light and the parking brake light that appeared on my dash. Parking brake seems to work though. Here's the scan:
Tuesday,31,December,2019,14:33:30:02198
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ4E53N002404 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 07 08 09 15 16 17 18 19 1E 25 28 34 37 38 42 46
47 4F 52 53 55 56 57 61 62 69 72 76 77
VIN: WAUZZZ4E53N002404 Mileage: 275780km-171361miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 1010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 HW: 4E0 907 560
Component: 4.2L V8/5V G 0080
Revision: 00000000 Serial number: AUX3Z0B9102748
Coding: 0011773
Shop #: WSC 02353 785 00200
VCID: 5EE56298BC371C979BB-800A
5 Faults Found:
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
18284 - Valve for Torque Support Mount
P1876 - 004 - Open Circuit - Intermittent
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 HW: 09E 927 156
Component: AG6 09E 4,2L5V RdW 0100
Coding: 0000001
Shop #: WSC 22829 142 16354
VCID: 5F9B5F9CBB3D159F90D-800A
1 Fault Found:
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller - Intermittent
Freeze Frame:
RPM: 1280 /min
RPM: 1312 /min
RPM: 1152 /min
(no units): 36.0
(no units): 22.0
Temperature: 55.0°C
T.B. Angle: 0.8°
Voltage: 13.68 V
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0400
Coding: 0008597
Shop #: WSC 00046 000 00000
VCID: 211F1964CDC9636FE69-8074
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131
Component: FBS AUDID3 H01 0070
Revision: 00702901 Serial number: AUX3Z0B9102748
Coding: 0262144
Shop #: WSC 02311 785 00200
VCID: 58E97480DE13E2A7D17-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
No fault code found.
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300B4037515501
Coding: 0000002
Shop #: WSC 00000 000 00000
VCID: 3A2DCE08405F10B7C73-806E
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000023587
Subsystem 3 - Serial number: 0131.10.060000000100010029˙
Subsystem 4 - Serial number: 010029˙
2 Faults Found:
02257 - Remote Control Receiver
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 35
Mileage: 275556 km
Time Indication: 0
Date: 2019.12.28
Time: 21:40:38
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 27
Reset counter: 41
Mileage: 275556 km
Time Indication: 0
Date: 2019.12.28
Time: 21:54:44
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 011 0130
Revision: 00000007 Serial number: 00000000004422
Coding: 0069843
VCID: 5AED6E88A01FF0B7E73-800E
11 Faults Found:
00711 - Left Footwell Flap Positioning Motor (V108)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 7
Reset counter: 75
Mileage: 275556 km
Time Indication: 0
Date: 2019.12.28
Time: 21:40:46
Freeze Frame:
Voltage: 11.60 V
Temperature: 19.0°C
(no units): 80.0
(no units): 98.0
Temperature: -85.0°C
01274 - Air Flow Flap Positioning Motor (V71)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 80
Mileage: 275556 km
Time Indication: 0
Date: 2019.12.28
Time: 21:40:47
Freeze Frame:
Voltage: 11.60 V
Temperature: 19.0°C
(no units): 80.0
(no units): 98.0
01592 - Air Quality Sensor (G238)
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 41
Mileage: 275556 km
Time Indication: 0
Date: 2019.12.28
Time: 21:40:50
Freeze Frame:
Temperature: 23.0°C
01087 - Basic Setting Not Performed
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 227
Mileage: 271544 km
Time Indication: 0
Date: 2002.09.13
Time: 01:30:31
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 5
Reset counter: 39
Mileage: 275556 km
Time Indication: 0
Date: 2019.12.28
Time: 21:40:51
Freeze Frame:
Voltage: 11.60 V
00716 - Air recirculation Flap Positioning Motor (V113)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 50
Reset counter: 80
Mileage: 275556 km
Time Indication: 0
Date: 2019.12.28
Time: 21:40:55
Freeze Frame:
Voltage: 11.60 V
Temperature: 18.0°C
(no units): 75.0
(no units): 98.0
00819 - High Pressure Sensor (G65)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 80
Mileage: 275558 km
Time Indication: 0
Date: 2019.12.28
Time: 22:03:18
00066 - Rear Right Footwell Heater (Z43)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 18
Reset counter: 80
Mileage: 275558 km
Time Indication: 0
Date: 2019.12.28
Time: 22:03:22
Freeze Frame:
Voltage: 14.20 V
00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 9
Reset counter: 80
Mileage: 275558 km
Time Indication: 0
Date: 2019.12.28
Time: 22:03:24
Freeze Frame:
Voltage: 14.10 V
(no units): 131.0
(no units): 255.0
00710 - Defroster Flap Positioning Motor (V107)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 15
Reset counter: 76
Mileage: 275584 km
Time Indication: 0
Date: 2019.12.29
Time: 18:24:52
Freeze Frame:
Voltage: 14.20 V
Temperature: 16.0°C
(no units): 70.0
(no units): 89.0
Temperature: -95.0°C
Raw, Form. N/A: 000 000 000
00728 - Potentiometer in Positioning Motor for Left-Hand Central Vent (G136)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 80
Mileage: 275782 km
Time Indication: 0
Date: 2019.12.31
Time: 14:08:53
Freeze Frame:
Voltage: 14.10 V
(no units): 1.0
(no units): 0.0
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 A HW: 4E0 907 279 A
Component: ILM Fahrer H11 0060
Coding: 0011012
Shop #: WSC 80248 790 00005
VCID: 26150A78A4E7845793B-8072
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0310
Coding: 00000030
Shop #: WSC 80248
2 Faults Found:
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 275789 km
Time Indication: 0
Date: 2019.12.31
Time: 14:30:24
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 275789 km
Time Indication: 0
Date: 2019.12.31
Time: 14:30:24
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H08 0840
Coding: 0431707
Shop #: WSC 02313 785 00200
VCID: 6393536C9755317FB45-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H08 0020
Coding: 0012141
VCID: 65974D7499614F4F5A1-8030
Component: Lenkradmodul H06 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 900 E
Component: KOMBIINSTR. VDO H33 0020
Revision: 5 992703 Serial number: AUDID3B9003509
Coding: 0000103
VCID: 5CE16890AA2B0E87F5F-8008
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 HW: 4E0 265 081
Component: Heizgeraet H06 0280
Revision: 0000000E Serial number: 00000009001484
VCID: 59EF7184A519FBAFEE9-800C
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H06 0070
Revision: 06 Serial number: 0000302A1609FC
Coding: FDFE7FC62B3504
2 Faults Found:
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 20
Reset counter: 41
Mileage: 275556 km
Time Indication: 0
Date: 2019.12.28
Time: 21:41:17
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 81
Mileage: 275747 km
Time Indication: 0
Date: 2019.12.31
Time: 11:34:28
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Serial number: AUZ5ZBC1011215
VCID: 1C612890EAAB4E8735F-8048
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0262144
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 011 0100
Revision: 00000040 Serial number: 00000000001645!
VCID: 619F59648D49236FA69-8034
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 C HW: 4E0 907 553 C
Component: LUFTFDR.-CDC H03 4190
Coding: 0015500
VCID: 2313136CD7D5717FF45-8076
3 Faults Found:
01437 - Control Position not Learned
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 35
Mileage: 275556 km
Time Indication: 0
Date: 2019.12.28
Time: 21:41:20
00776 - Level Control System Sensor; Left Front (G78)
Freeze Frame:
Fault Status: 11101100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 41
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 81
Mileage: 275747 km
Time Indication: 0
Date: 2019.12.31
Time: 11:34:28
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H41 1060
Revision: 00000000 Serial number: 305JL027508720
VCID: 3B23CB0C4F6529BFDC5-806E
4 Faults Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 7
Fault Frequency: 21
Reset counter: 41
Mileage: 275556 km
Time Indication: 0
Date: 2019.12.28
Time: 21:41:27
Freeze Frame:
Hex Value: 0x5E0B
Hex Value: 0x5B81
Hex Value: 0x0000
Hex Value: 0x0010
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 81
Mileage: 275747 km
Time Indication: 0
Date: 2019.12.31
Time: 11:34:33
Freeze Frame:
Bin. Bits: 1100
03183 - Data Media not Compatible
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 152
Reset counter: 41
Mileage: 275556 km
Time Indication: 0
Date: 2019.12.28
Time: 21:41:27
Freeze Frame:
Hex Value: 0x5E0B
Hex Value: 0x5BF9
Hex Value: 0x0000
Hex Value: 0x0000
02927 - DVD Read Error
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 69
Reset counter: 81
Mileage: 275556 km
Time Indication: 0
Date: 2019.12.28
Time: 21:54:48
Freeze Frame:
Hex Value: 0x5E0B
Hex Value: 0x5BE7
Hex Value: 0x0401
Hex Value: 0x0204
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0090
Serial number: 00000331000171
Coding: 0003734
Shop #: WSC 28100 141 17409
VCID: 1D672594F1B1478FC21-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM004 0060
Coding: 0002848
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040310240183
Coding: 0000600
VCID: 270B077CA3ED9D5FA8D-8072
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H01 0020
3 Faults Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 41
Mileage: 245937 km
Time Indication: 0
Date: 2015.12.07
Time: 08:50:12
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 81
Mileage: 275727 km
Time Indication: 0
Date: 2019.12.31
Time: 10:39:11
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 81
Mileage: 275747 km
Time Indication: 0
Date: 2019.12.31
Time: 11:34:29
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H12 0460
Revision: PROD_01O Serial number: 00000000096737
Coding: 0000026
VCID: 2A0DFE48B0FFA037B73-807E
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 81
Mileage: 275747 km
Time Indication: 0
Date: 2019.12.31
Time: 11:34:29
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000038207
Coding: 0010101
VCID: 1E652298FCB75C97DBB-804A
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 81
Mileage: 262136 km
Time Indication: 0
Date: 2063.15.31
Time: 16:00:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM004 0060
Coding: 0002848
2 Faults Found:
01482 - Motors for Central Locking
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 2
Reset counter: 78
Mileage: 275616 km
Time Indication: 0
Date: 2019.12.30
Time: 06:42:12
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 14
Reset counter: 81
Mileage: 275760 km
Time Indication: 0
Date: 2019.12.31
Time: 13:31:36
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000531
VCID: 1F1B1F9CFBBD559FD0D-804A
2 Faults Found:
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 10
Reset counter: 81
Mileage: 275744 km
Time Indication: 0
Date: 2019.12.31
Time: 11:34:47
Freeze Frame:
Voltage: 13.56 V
Count: 236
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 81
Mileage: 275744 km
Time Indication: 0
Date: 2019.12.31
Time: 11:34:28
Freeze Frame:
Voltage: 13.56 V
Count: 242
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: AFS 1.Stufe H01 0020
Revision: 00000001 Serial number:
Coding: 0000001
VCID: 629D5668884F3877BF3-8036
3 Faults Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 35
Mileage: 275560 km
Time Indication: 0
Date: 2019.12.28
Time: 21:42:05
01310 - Level Control System Control Module (J197)
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 35
Mileage: 275560 km
Time Indication: 0
Date: 2019.12.28
Time: 21:42:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 255
Reset counter: 81
Mileage: 275752 km
Time Indication: 0
Date: 2019.12.31
Time: 11:34:28
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 L
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 388AS067509324
Coding: 0000001
Shop #: WSC 31414 790 00001
VCID: 313FE9249D29D3EF769-8064
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 29
Reset counter: 40
Mileage: 271544 km
Time Indication: 0
Date: 2002.09.14
Time: 20:24:58
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 E HW: 4E0 919 148
Component: R0078 TVhybridT 0470
Revision: R0H06000 Serial number: 76300800716502
Coding: 0000302
VCID: 25170D74D9E18F4F9A1-8070
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000000002487
Shop #: WSC 22829 142 13099
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 0404050245
Coding: 303030393135313035414B56413030343034303530323435
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 2
Reset counter: 78
Mileage: 275558 km
Time Indication: 0
Date: 2019.12.29
Time: 04:43:54
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0060
Coding: 0003872
VCID: 5DE76594B131078F821-8008
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 81
Mileage: 275760 km
Time Indication: 0
Date: 2019.12.31
Time: 13:31:36
Address 69: Trailer Labels: None
Part No HW: 4E
VCID: 55F77DB4C901DFCFCA1-8000
Component:
Shop #: WSC 65536 001 394790
1 Fault Found:
00526 - Brake Light Switch (F)
Freeze Frame:
Fault Status: 00000000
Fault Priority: 0
Fault Frequency: 20
Reset counter: 82
Mileage: 93185 km
Time Indication: 0
Date: 2000.00.20
Time: 00:16:02
Freeze Frame:
Raw, Index/Key Err.: 252 000 000
Chan. Number: 45
Resistance: 6 ohms
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0060
Coding: 0003872
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0011008
VCID: 60995C6086432A67A97-8034
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 81
Mileage: 275747 km
Time Indication: 0
Date: 2019.12.31
Time: 11:34:29
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 02:24, VBatt start/end: 11.8V/12.0V)-----------
The ABS control module error seems to show up everywhere. I just don't know where to start. Can anyone make any sense of this?
Also, the ABS unit/pump keeps going and going after the car is shut off. Have to disconnect it to make it stop. Is it the control module that is shot? Relay(is that J329?)? Wiring? Can a bad module be responsible for some of the other fault codes I have?
I've cleared the codes but they come back
Old 7th January 2020, 02:49 PM
A couple of things before delving into the VCDS scan.
Since you're a new member, pop along to the Introductions section and introduce yourself to everyone. We're a friendly lot, and we don't have many rules, but we do like to see other members cars, so photos are welcome. Also, to make things easier down the line when looking for assistance, amend your profile setup to include car details and a rough location. The car details may make it easier to help diagnose issues, and the location is just so if you need help, someone may just be round the corner, or maybe just to meet up for a chat.
Now, the scan. You make the comment about the ABS errors occurring in several modules, and it is remarkable how these cars work, and how they are all seemingly interconnected, so yes, an error may appear in what seems like an odd location/module.
The majority of the errors appear around the same date, but there some other odd anomalies around dates and other data. You have one error with a date of 2000, yet the car is an '03 model. You also have a error with a temperature reading of -85 degrees, which is somewhat chilly!
Since you have VCDS, what I'd suggest you do is always save a copy of the scan, as it may be useful later on. The next thing to do is clear all the codes (some codes may not clear is they are classed as a 'permanent' fault, and will only clear by replacing/repairing the offending item). Once you've done that, take the car for a drive, and then scan the car again, and you should hopefully have fewer errors second time around. Error codes can occur because the battery was disconnected at some time, and this could account for some of them. Post up what's left, and then we can go from there.
Regarding the ABS specific issue, and the pump continuing to run, one suggestion I came across was a faulty relay (which you hint at). I can identify the relevant relay on the D2 platform, but at the moment can't find the equivalent of the D3 platform.
Old 7th January 2020, 03:09 PM
Hi. Thanks for the reply. Will definitely pop in to introduce myself. I do have a copy of the scan(before and after) and I've cleared the codes and gone for a drive. Did a scan again and these came back
The only relay I can find that is connected to the ABS unit is J329. It's the terminal 15 relay. Would a faulty realy cause all these ABS module codes though?
This is the first scan. Then I drove for about 100 miles and did a scan again(the one in the 1st post):
Code:
Saturday,28,December,2019,21:32:15:02198
www.Ross-Tech.com
VIN: WAUZZZ4E53N002404   Mileage: 275550km-171218miles
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 1010
1E-Media Player 2 -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
57-TV Tuner -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
   Coding: 0011773
6 Faults Found:
18010 - Power Supply Terminal 30
            P1602 - 002 - Voltage too Low - Intermittent
16825 - EVAP Emission Control Sys
            P0441 - 002 - Incorrect Flow - Intermittent
17538 - Fuel Trim; Bank 2 (Mult)
            P1130 - 001 - System too Lean - Intermittent
17536 - Fuel Trim; Bank 1 (Mult)
            P1128 - 001 - System too Lean - Intermittent
   Coding: 0000001
2 Faults Found:
18005 - Powertrain Databus
            P1597 - 000 - Missing Message from Level Control System (J197) - Intermittent
             Freeze Frame:
                    RPM: 1376 /min
                    RPM: 1312 /min
                    RPM: 0 /min
                    (no units): 25.0
                    (no units): 32.0
                    Temperature: 26.0°C
                    T.B. Angle: 0.0°
                    Voltage: 10.72 V
18290 - Powertrain Data Bus
            P1882 - 000 - Missing Message from Electric Parking Brake Controller - Intermittent
             Freeze Frame:
                    RPM: 1376 /min
                    RPM: 1312 /min
                    RPM: 0 /min
                    (no units): 25.0
                    (no units): 32.0
                    Temperature: 26.0°C
                    T.B. Angle: 0.0°
                    Voltage: 10.72 V
   Coding: 0008597
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
   Coding: 0262144
   Component: ELV                 XXXX
1 Fault Found:
00668 - Supply Voltage Terminal 30
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 0
                    Reset counter: 74
                    Mileage: 275248 km
                    Time Indication: 0
                    Date: 2019.12.26
                    Time: 05:17:56
   Coding: 0000002
10 Faults Found:
            014 - Defective
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 271758 km
                    Time Indication: 0
                    Date: 2002.09.14
                    Time: 01:42:27
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 89
                    Reset counter: 75
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:55:09
02244 - Button in Control Head is Stuck
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 52
                    Mileage: 273790 km
                    Time Indication: 0
                    Date: 2002.09.16
                    Time: 18:56:46
             Freeze Frame:
                    Bin. Bits: 00000000
                    Bin. Bits:  0000001
                    Bin. Bits:      000
01327 - Control Module for Parking Aid (J446)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 51
                    Mileage: 271548 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:14:00
01317 - Control Module in Instrument Cluster (J285)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 51
                    Mileage: 273775 km
                    Time Indication: 0
                    Date: 2019.11.27
                    Time: 08:20:48
             Freeze Frame:
                    Bin. Bits:       01
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 51
                    Mileage: 273776 km
                    Time Indication: 0
                    Date: 2019.11.27
                    Time: 08:24:47
02103 - Control Module 2 for Vehicle Electrical System (J520)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 51
                    Mileage: 273775 km
                    Time Indication: 0
                    Date: 2019.11.27
                    Time: 08:21:17
00384 - Optical Databus
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 6
                    Reset counter: 40
                    Time Indication: 15
00658 - Control Head
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 271546 km
                    Time Indication: 0
                    Date: 2002.11.27
                    Time: 09:30:08
00532 - Supply Voltage B+
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 74
                    Time Indication: 15
   Coding: 0069843
17 Faults Found:
            014 - Defective
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 14
                    Reset counter: 35
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:30:03
             Freeze Frame:
                    Temperature: 17.0°C
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 31
                    Reset counter: 74
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:30:03
             Freeze Frame:
                    Voltage: 12.00 V
             Freeze Frame:
                    Fault Status: 01100011
                    Fault Priority: 3
                    Reset counter: 35
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:30:16
             Freeze Frame:
                    Voltage: 12.00 V
                    Temperature: 18.0°C
                    (no units): 78.0
                    (no units): 72.0
                    Temperature: -84.0°C
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 227
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 01:30:31
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 225
                    Reset counter: 47
                    Mileage: 271731 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 09:31:17
             Freeze Frame:
                    Voltage: 14.10 V
                    Temperature: 13.0°C
                    (no units): 70.0
                    (no units): 77.0
                    Temperature: -91.0°C
00020 - Motor for Blocking Flap; Defrost and Body Vents; Right (V199)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 39
                    Reset counter: 71
                    Mileage: 272173 km
                    Time Indication: 0
                    Date: 2019.10.18
                    Time: 13:46:48
             Freeze Frame:
                    Voltage: 13.70 V
                    Temperature: 12.0°C
                    (no units): 70.0
                    (no units): 88.0
                    Temperature: -89.0°C
00021 - Motor for Blocking Flap; Defrost and Body Vents; Left (V200)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 15
                    Reset counter: 74
                    Mileage: 273857 km
                    Time Indication: 0
                    Date: 2019.12.07
                    Time: 15:45:15
             Freeze Frame:
                    Voltage: 13.90 V
                    Temperature: 13.0°C
                    (no units): 75.0
                    (no units): 88.0
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 83
                    Reset counter: 35
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.14
                    Time: 13:27:28
             Freeze Frame:
                    Voltage: 13.20 V
                    Temperature: 14.0°C
                    (no units): 80.0
                    (no units): 76.0
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 22
                    Reset counter: 73
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.17
                    Time: 12:01:40
             Freeze Frame:
                    Voltage: 13.50 V
                    (no units): 1.0
                    (no units): 0.0
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 75
                    Reset counter: 35
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.17
                    Time: 12:02:08
             Freeze Frame:
                    Voltage: 13.70 V
                    Temperature: 4.0°C
                    (no units): 75.0
                    (no units): 93.0
                    Temperature: -97.0°C
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 19
                    Reset counter: 74
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.17
                    Time: 12:02:42
             Freeze Frame:
                    Voltage: 13.70 V
01869 - Rear Left Cold / Warm Air Outlet Motor Position Sensor (G351)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 47
                    Mileage: 271564 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:04:32
             Freeze Frame:
                    Voltage: 14.10 V
                    (no units): 140.0
                    (no units): 255.0
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 113
                    Reset counter: 68
                    Mileage: 271566 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:15:04
             Freeze Frame:
                    Voltage: 12.80 V
                    (no units): 78.0
                    (no units): 255.0
00729 - Potentiometer in Positioning Motor for Right-Hand Central Vent (G137)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 32
                    Reset counter: 71
                    Mileage: 271568 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:05:05
             Freeze Frame:
                    Voltage: 13.80 V
                    (no units): 220.0
                    (no units): 255.0
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 52
                    Reset counter: 74
                    Mileage: 271606 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 01:03:36
00732 - Potentiometer in Positioning Motor for Right-Hand Footwell Flap (G140)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 19
                    Reset counter: 47
                    Mileage: 271719 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 02:41:52
             Freeze Frame:
                    Voltage: 14.00 V
                    (no units): 241.0
                    (no units): 255.0
01868 - Rear Right Warm/Cold Flap Air Outlet Motor (V221)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 26
                    Reset counter: 71
                    Mileage: 271720 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:05:44
             Freeze Frame:
                    Voltage: 14.10 V
                    Temperature: 20.0°C
                    (no units): 80.0
                    (no units): 82.0
                    Temperature: -87.0°C
   Coding: 0011012
   Coding: 00000030
   Shop #: WSC 80248
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 35
                    Mileage: 275556 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 21:29:00
00458 - Control Module for Battery Monitoring (J367)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 275260 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 35
                    Mileage: 275556 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 21:29:00
   Coding: 0431707
   Coding: 0012141
5 Faults Found:
00446 - Function Limitation due to Under-Voltage
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 74
                    Mileage: 271547 km
                    Time Indication: 0
                    Date: 2002.12.15
                    Time: 15:53:30
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 40
                    Time Indication: 0
                    Date: 2063.15.31
                    Time: 31:63:40
01336 - Company Data Bus for Comfort System
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 74
                    Time Indication: 0
                    Date: 2063.15.31
                    Time: 31:63:40
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 74
                    Time Indication: 0
                    Date: 2063.15.31
                    Time: 31:63:40
02071 - Local Databus
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 74
                    Mileage: 271548 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:14:42
   Coding: 0000103
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
             Freeze Frame:
                    Fault Status: 00000011
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 271730 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:02:34
2 Faults Found:
02072 - Control Module for Energy Management (J644)
01406 - No Flame
            000 - -
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Reset counter: 35
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:36:35
01207 - Control Module for Auxiliary Heater (J364)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 36
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:54:32
01517 - Control Module for Trailer/Towing Sensor (J345)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 50
                    Mileage: 273763 km
                    Time Indication: 0
                    Date: 2019.11.24
                    Time: 19:07:15
2 Faults Found:
02261 - Data Medium
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 58
                    Reset counter: 72
                    Mileage: 275250 km
                    Time Indication: 0
                    Date: 2019.12.22
                    Time: 15:26:23
             Freeze Frame:
                    Text: 0000EB11
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 275260 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:04:44
   Coding: 0262144
   Component: ELV                 XXXX
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 0
                    Reset counter: 74
                    Mileage: 275248 km
                    Time Indication: 0
                    Date: 2019.12.26
                    Time: 05:17:56
   Coding: 0015500
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 227
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 01:41:46
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 15
                    Reset counter: 35
                    Mileage: 0 km
                    Time Indication: 0
00778 - Steering Angle Sensor (G85)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 24
                    Reset counter: 51
                    Mileage: 271548 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:00:07
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 8
                    Reset counter: 56
                    Mileage: 271551 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:20:48
01598 - Drive Battery Voltage
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 275260 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:03:47
             Freeze Frame:
                    Hex Value: 0x5E07
                    Hex Value: 0x0C63
                    Hex Value: 0x0048
02261 - Data Medium
            014 - Defective
             Freeze Frame:
                    Fault Priority: 7
                    Reset counter: 35
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.14
                    Time: 11:51:01
             Freeze Frame:
                    Hex Value: 0x5E07
                    Hex Value: 0xC901
                    Hex Value: 0x0000
                    Hex Value: 0x0010
             Freeze Frame:
                    Fault Priority: 6
                    Reset counter: 75
                    Mileage: 271546 km
                    Time Indication: 0
                    Date: 2002.10.10
                    Time: 20:05:29
             Freeze Frame:
                    Hex Value: 0x5E07
                    Hex Value: 0xC335
                    Hex Value: 0x0000
                    Hex Value: 0x0000
            000 - -
             Freeze Frame:
                    Fault Priority: 6
                    Reset counter: 35
                    Mileage: 271546 km
                    Time Indication: 0
                    Date: 2002.10.29
                    Time: 09:55:28
             Freeze Frame:
                    Hex Value: 0x5E07
                    Hex Value: 0xC965
                    Hex Value: 0x0401
                    Hex Value: 0x0204
   Coding: 0003734
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 52
                    Mileage: 262136 km
                    Time Indication: 0
                    Date: 2002.11.27
                    Time: 09:13:00
             Freeze Frame:
                    Bin. Bits: 10000000
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 74
                    Mileage: 262136 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:03:00
   Coding: 0002848
3 Faults Found:
00913 - Window Regulator Switch; Front Right Driver (E81)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 64
                    Mileage: 274512 km
                    Time Indication: 0
                    Date: 2019.12.14
                    Time: 14:57:30
02111 - Motor for Window Regulator
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 275248 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:03:42
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 275248 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:03:42
   Coding: 0000600
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Reset counter: 35
                    Mileage: 245937 km
                    Time Indication: 0
                    Date: 2015.12.07
                    Time: 08:50:12
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 74
                    Mileage: 275260 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:04:45
00892 - Switch for Trunk Closing Cylinder (F248)
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 3
                    Fault Frequency: 48
                    Reset counter: 75
                    Mileage: 272150 km
                    Time Indication: 0
                    Date: 2019.10.12
                    Time: 10:52:51
01501 - Bulb for Blinkers; Rear Left (M6)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 64
                    Mileage: 274563 km
                    Time Indication: 0
                    Date: 2019.12.14
                    Time: 18:59:51
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 119
                    Reset counter: 72
                    Mileage: 271546 km
                    Time Indication: 0
                    Date: 2002.10.10
                    Time: 21:58:18
   Coding: 0000026
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 275260 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:03:44
   Coding: 0010101
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 51
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2023.06.06
                    Time: 00:00:00
             Freeze Frame:
                    Fault Status: 00110010
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 74
                    Mileage: 262136 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:04:00
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 74
                    Mileage: 262136 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:03:00
   Coding: 0002848
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 275248 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:03:42
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 275248 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:03:42
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 14
                    Reset counter: 75
                    Mileage: 275536 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 15:20:40
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 14
                    Reset counter: 35
                    Mileage: 275552 km
                    Time Indication: 0
   Revision: A32C0220
   Coding: 0000531
   Coding: 0000001
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 227
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:16:58
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 227
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:16:58
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 0
                    Reset counter: 40
                    Mileage: 271560 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:14:02
02234 - Right Headlight Power Output Stage (J668)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 0
                    Reset counter: 40
                    Mileage: 8 km
                    Time Indication: 0
   Coding: 0000001
2 Faults Found:
00856 - Radio Antenna
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 36
                    Mileage: 272951 km
                    Time Indication: 0
                    Date: 2019.11.06
                    Time: 09:58:50
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 25
                    Reset counter: 24
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.14
                    Time: 20:24:58
   Coding: 0000302
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 275260 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:04:14
00863 - Antenna 1 for TV (R55)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 36
                    Mileage: 272925 km
                    Time Indication: 0
                    Date: 2019.11.06
                    Time: 09:18:31
00864 - Antenna 2 for TV (R56)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 52
                    Reset counter: 37
                    Mileage: 272920 km
                    Time Indication: 0
                    Date: 2019.11.06
                    Time: 07:50:18
00866 - Antenna 4 for TV (R58)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 14
                    Reset counter: 36
                    Mileage: 272921 km
                    Time Indication: 0
                    Date: 2019.11.06
                    Time: 09:16:14
5 Faults Found:
02273 - Quiescent Current Stage 2
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 23
                    Reset counter: 255
                    Mileage: 271544 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 01:47:32
02254 - Interface to Generator
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 75
                    Mileage: 271730 km
                    Time Indication: 0
                    Date: 2002.09.13
                    Time: 00:01:21
02276 - Quiescent Current Stage 5
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 18
                    Reset counter: 255
                    Mileage: 271546 km
                    Time Indication: 0
                    Date: 2002.11.12
                    Time: 03:08:25
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 275260 km
                    Time Indication: 0
                    Date: 2019.12.26
                    Time: 11:45:44
02277 - Quiescent Current Stage 6
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 275264 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 10:52:24
   Coding: 0003872
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 275248 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:03:42
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 275248 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:03:42
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 14
                    Reset counter: 35
                    Mileage: 275552 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 16:41:42
   Part No HW: 4E
   Component:
2 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 20
                    Reset counter: 82
                    Mileage: 158721 km
                    Time Indication: 0
                    Date: 2000.00.20
                    Time: 00:16:02
             Freeze Frame:
                    Chan. Number: 130
                    Resistance: 9 ohms
00008 - Control Circuit for Left Fog Lamp
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 20
                    Reset counter: 82
                    Mileage: 158721 km
                    Time Indication: 0
                    Date: 2000.00.20
                    Time: 00:16:02
   Coding: 0003872
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 14
                    Reset counter: 66
                    Mileage: 275008 km
                    Time Indication: 0
                    Date: 2019.12.16
                    Time: 08:43:36
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 14
                    Reset counter: 40
                    Mileage: 275216 km
                    Time Indication: 0
                    Date: 2019.12.19
                    Time: 07:17:30
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 275248 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:03:42
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 275248 km
                    Time Indication: 0
                    Date: 2019.12.28
                    Time: 08:03:42
   Coding: 0011008
Cannot be reached
End----(Elapsed Time: 02:21, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
So almost all ABS/Brake errors happened between these 2 scans. I guess when the brake warning lights started appearing
Old 7th January 2020, 03:34 PM
I am new to D3 myself so not much experience yet but in general ABS pump should only be running when ABS/ESP/EDL is activated, not all the time. I don't think there are any external relays for ABS. Looks like your ABS unit is shorted causing pump to run all the time. I don't know if it has internal relay which could be stuck on or if it is activated with transistor which could be shorted. Pump running all the time could cause voltage drop in the unit especially if battery is weak and that could result in communication errors.
Old 7th January 2020, 03:50 PM
So your guess would be the ABS module itself?
The first time I noticed the running pump after the car was shut off, was on NYE(Dec. 31). That was the first time. Haven't driven it since(well, I drove it home). I bought the car Dec. 27.
A8 D3 2003 4.2 Quattro Engine: BFM / Gearbox: GNU
Old 7th January 2020, 05:23 PM
If you are resetting each time, and all those errors are coming back - I would focus on the low voltage ones as it shouldnt be flagging up voltage errors on a good battery.
If you don't have a good battery and stable voltage, all kinds of weird things can happen.
if the battery is good, it might be a faulty or mis-calibrated power module....
You could try disconnecting the battery, charging it to full and then recoding the battery module to get things back in sync if it is definitely a good battery.
I wouldn't waste time diagnosing anything else until the power is stable....
Old 7th January 2020, 05:45 PM
The low voltage codes doesn't show up on my latest scan(1st post). Did a scan when I bought the car. Cleared the codes and went for a drive and scanned again(3 days later). The scan in my latest post is the 1st scan
But I will disconnect the battery and charge it
Old 7th January 2020, 07:20 PM
Ian, are there any fuses for the ABS unit? Just wondering if it would be worthwhile pulling them once they get the battery charged, so that it isn't causing a continuous drain. That way they could hopefully clear all the errors caused by low voltage issues, and just be left with the 'real' errors. I'm not suggesting they drive the car like that on the road, but at least it will give them a better view of what the other issues are, including the ABS one, and hopefully not make it look as bad to overcome.
Some of the errors in the first post (most recent scan) are still old ones, so I'd also suggest going into each module and clearing them within the module, but as IT says, you'll need to get the battery issue sorted first.
Old 7th January 2020, 07:35 PM
If I wash the car in a automatic car wash, including underbody with no splash guard underneath the car, could that affect/screw up the electronics? I think the warning lights showed up after that. Not immediately though. Most likely not the issue, just speculating
Old 9th January 2020, 10:53 AM
Nothing is impossible, but I would highly doubt it, as all the electrical connectors on the outside of the car are designed to prevent water ingress. I've used car washes in the past without issue.
If you're concerned that water may have been the issue, I'd check the plenum chamber in the engine bay to ensure it isn't full of water, and I'd also check the carpets in the front to see if any water has gotten into the car.
