Old 9th January 2022, 01:39 PM
RICKY D's Avatar
RICKY D RICKY D is offline
I must have missed the thread on this already - I love it
Just need one for the boot lid and one for the dash instead of the Quattro badge
2016 S5 Coupe Black Edition - Ibis White
Old 9th January 2022, 01:59 PM
What about on the number plate. Would look better than "Trotters Independent Motahs" or whatever is stamped there at the moment...
Mind you, there has to be an intrinsic value to carrying the D2 Doctor name so maybe all genuine MJ worked on motors need a serial number for verification.....
Paul
Gosport UK
________________________
Audi S8 2002 FE Avus Silver / Extended Red Leather.
Daily Driver: BMW 3 series GT - Just more practical for my camping trips!
Old 9th January 2022, 04:37 PM
Sit down, Waldo Sit down, Waldo is offline
Shiny new plates subtly carrying your unique D2 Doctor heritage number? Like it
Old 9th January 2022, 06:59 PM
Hmm. Noted.
Engine out:
Started stripping everything off. The power steering pump will sit in evaporust for a while to hopefully allow the pulley to be removed from the hub
On the separating table
Easy as that
Red atf Not that the 5HP cares, given that the murple did 20k on diff oil Still, I'll put the proper stuff in it.
There's some crust around most of the coolant connections so all of these will get cleaned and the hoses & o-rings replaced.
I left the engine and gearbox to drain overnight. They'll go on stands and start coming apart tomorrow
ID:	27625   Click image for larger version
ID:	27626   Click image for larger version
ID:	27627   Click image for larger version
ID:	27628   Click image for larger version
ID:	27629   Click image for larger version
ID:	27630   Click image for larger version
ID:	27631   Click image for larger version
Old 10th January 2022, 07:33 PM
Getting the gearbox ready for its service. As it has been 'recently' refurbished, I don't plan on draining the diffs - the oil in them is nice and clean. However, if I flip it over to do the sump and filter all the oil will dribble out of the vents. That is solved with some 3d printed polyurethane bungs
The torque converter was rebuilt by JP Automatics in Bristol, which is a good sign
After sitting in Evaporust overnight, the power steering pump relinquished the pulley with a little help from the bearing puller and the mapp torch
The hub cleaned up nicely
A little corrosion on the pulley is easily dealt with
Engine and gearbox ready for shenanigans
ID:	27635   Click image for larger version
ID:	27636   Click image for larger version
ID:	27637   Click image for larger version
ID:	27638   Click image for larger version
ID:	27639   Click image for larger version
Old 11th January 2022, 09:03 AM
This may have been asked before but is there a way of checking the oil levels in the differentials?
Paul
Gosport UK
Old 11th January 2022, 10:13 AM
They are filled to the bottom of the fill plug. Basically open the plug, put oil in until it overflows. This should be done with the drivetrain level so I will check and top up if necessary once the engine and box are back together
Old 11th January 2022, 12:25 PM
OK. I have a leaky rear (must be age) so will go with the 'top up and hope' scenario at first before tackling more stuff to do.
Paul
Gosport UK
Old 11th January 2022, 12:52 PM
They often leak from the right hand output shaft on the rear diff. The fill plug is just behind the output flange, about halfway up
Old 11th January 2022, 05:47 PM
Is it these ones indicated? And is it the same on the 5HP19?
PNG version picture
JPG Version picture
Paul
Gosport UK
