Old 15th January 2021, 06:53 PM
GH77 GH77 is offline
Originally Posted by GH77 View Post
Can we even get adjustment motors for the D3 headlights? .
Actually, I'll answer my own question there. Yes, we can. 4F0941293A (No9 in the diagram) and it looks removable from the back of the housing so no need to take the front lens off like in the D2. Would need to drop the bumper and remove the headlight though.
Name:	Exploded diagram Screenshot 2021-01-15 195227.png
ID:	25178   Click image for larger version
ID:	25179   Click image for larger version
Name:	D3 range control motor - Screenshot 2021-01-15 195512.png
2000 FL A8 3.7 QS - Turned 21 years old on 15th March 2021. Ming Blue - 175k miles. I love having a 90's car worthy of 90L of 98 RON! If only they still did 4* fully leaded!
2009 A8 4.2 FSi LWB - Marine Blue - 164k miles. Extras? Too many to list. But I do like the Rear Seat Entertainment . . . . . .
477k miles to the moon and back. 238k to go and between them they'll have made it!
Old 15th January 2021, 07:14 PM
I have tried a lot of aftermarked HID and LED lights in my cars but they all have some issues. LEDs are definitely better and there are no major problems with high beam and larger bulbs like H7 or 9005 as they are only on for short periods of time and bigger body helps with heat dissipation but dipped beam H1 are too small, lower light output and does not last beacause they overheat. Only problem with LEDs in high beam reflector is that light output is not uniform, you get some lighter and some darker spots.
I have a project lined up, I bought a 2017 Quasqai LED headlight for £20 including shipping on ebay for research and they are often available for a similar price. The good news are that there are no fancy electronics in them just straight power connection so easy to connect. Downside is that projector unit is only dipped beam with full beam separate. Dipped beam should be pretty easy to trasnfer projector unit over, I don't think it uses standard Hella mounting points for straight swap-over but should be easy enough to fabricate adapter plate. A bit harder if you want to use full beam from them as well.
As its all designed together light source and projector unit it should work well without dazzling other road users and the LEDs should be decent quality with good CRI and also suitable heat dissipation so should last long time unlike most aftermarket.
PS
Here is a short video of my A6 with aftermarket LED bulbs for both dipped and full beam. It's just dipped at the very start and then switch over to full beam. You can see in video what I mean about dark and bright spots. It's a wmv file as size limit on forum for .avi is too small. To be honest dipped beam is not much improvement over halogen but full beam is much better. For some reason my Windows 10 default built in media player does not play it but it works fine with VLC player.
Old 15th January 2021, 07:47 PM
Thanks for the link Gregor
My headlights have been out recently so all should be fine. I also refurbed them a few years back but unfortunately never lacquered them so this will be a job for spring.
Old 15th January 2021, 09:03 PM
Don't let the laquer overspray get on the floor! Proper slippy
Old 15th January 2021, 09:09 PM
Can't argue with that for an improvement!
Old 18th January 2021, 01:17 PM
MoT rule on this have just changed apparently
https://www.gov.uk/guidance/mot-insp...#section-4-1-4
"Existing halogen headlamp units should not be converted to be used with high intensity discharge (HID) or light emitting diode (LED) bulbs. If such a conversion has been done, you must fail the headlamp."
Whether this makes any practical difference remains to be seen. As ever the only actual sin is getting caught.....
Nick
Old 18th January 2021, 01:25 PM
Interesting. So in that case my A6 with retrofitted OE bixenon headlamps, manual levelling and no washing is just fine
