#111
Soooo.... wind back the clock to Sunday when everything was just oily and not broken. Insert Time And Relative Dimensions In Space joke here...
I've decided this AQH is too much work right now, as I have a couple of fixed points in time coming up and I need this one turned round quickly. While the engine mount is fixable, its going to take a week or so of ordering and making tooling, making the repair insert, and actually applying it, plus fixing everything else like the inlet manifold, injectors etc and I just don't have time. I've got a spare AVP from stock and I'm going to do all the same work to that instead, and I'll sort the AQH out later. Part of the role of this car is to allow me to test all my spare engines and get them all rebuilt and ready to use, so I've just shuffled the order a bit. AQH on the left, wrapped up to stop anything getting in the inlet ports, replacement AVP on the right Started stripping it down So much cleaner! Obviously this has set me back a couple of days of cleaning, but it will save much more than that since this engine is in a far better state to begin with It also had a genuine timing belt kit and water pump fitted shortly before it was decomissioned so all that stuff is in pretty good condition and can be re-used, apart from the belt which will be new. |
#112
hmm, I can see that the breather hoses are also a much better design than on 2,8 where it has those nasty corrugated plastic pipes that make it easy for debris to settle on to and crack after a few years...
#113
Regarding the wrapping of the AQH to prevent dirt ingress, i see from the engine service manual that there's a set of engine bungs available (VAS 6122) but when i checked the price they were around 100$ a set!! And you would need a few a those MJ 100$ for a set of plastic bungs is a bit steep
And, a question for you MJ - whats the differences between the AQH and AVP? I see that there's a slight difference in torque (430@3500rpm and 420@3400 respectively) ?
#114
+1, beat me to it David...
Autos Autos everywhere... (1) 2015 Tesla Model S: (was 85D, now 90D ). Silent and deadly, and very fast... But not as fast as Ian's M3P- (2) 2002 D2 S8 Final Edition: Bulletproof and faultless: Brilliant Black with Extended (Red!) Leather. Three-times winner of Best D2 1st prize (3) 1997 Fiat Coupe 20v Turbo: Scots (! ) Green. Fragile, but beautiful. (4) 2010 Fiat Panda 100HP. White Pandamonium (Final Edition!!). Pure old-fashioned 6-speed go-karting. |
#115
Mechanically nothing as far as I can tell. It seems to be all about the shift from Euro 3 to Euro 4, and the consequent change from Bosch Motronic 7.1 on the AQH to 7.1.1 on the AVP. With that comes secondary O2 sensors, individual control of the cam timing, and a warning light if secondary air isn't working. They changed the software and so also changed the engine code. BCS is the American version of the same thing, again mechanically the same but with different emissions specs. Cylinder heads, pistons, cams etc all the same so the difference in output is likely down to software.
Ironically, while the FL2 S8 got all the new Euro 4 gear, its still actually rated Euro 3 whereas the FL2 3.7 and 4.2 did achieve Euro 4. Luckily for British FL2 S8 owners though, DVLA class all the FL2 V8s as Euro 4 David - funnily enough I have a few items from that engine bung set from the two brand new engines I use |
#116
Which is why my late FL2 AVP-engine S8 is compliant with the London ULEZ.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
#117
MJ, your next Mastermind question is this:
The AQH /BCS engines seem to matched with different gearbox IDs too. The AQH/BCS are attached to ECY (ZF Pt No 1058 020 013; Audi Pt No 01L 300 041S) whilst AVP/AYS are attached to FBG (always though that stood for "F*cking Big Gearbox) (ZF Pt No 1058 020 030; Audi Pt No 01L 300 042P) Why?
#118
Software changes again. ECY and FBG are exactly the same hardware, but with differences in the user interface - ECY has PRND432, FBG has PRNDS. You can put an ECY gearbox in an FL2 in place of an FBG and it works just fine. Likewise, you can put an FBG control unit and shifter in an FL1 with an ECY to get PRNDS (which I have done in mine and Mike's), although early FL1 clusters don't display the gear selection in the LCD as they don't understand the CAN messages.
#119
Damn. Ill have to try harder
#120
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
