Old 7th April 2014, 11:03 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
M-A8 Did you get anywhere with the testing?
I was wondering about the Main beam with coming/leaving home lights.
I did not think it would have anything to do with the Auto lights.
[center]
06 3.0TDI Quattro:
Options:
Old 7th April 2014, 11:12 AM
Not sure on the coming home function but I can confirm that if you have the lights in auto and the option is not on in the mmi for main beam you only get dipped beam headlights. God only knows why you would want to have no main beams???
Old 7th April 2014, 11:36 AM
ScottD3's Avatar
That seems stupid.
I wonder how many people set theirs to off and drive round with auto lights on and no dipped beams then?
[center]
06 3.0TDI Quattro:
Options:
Old 7th April 2014, 04:52 PM
So far I tried all sort of options for coming home and main beam function. No matter how is set, lights Auto or not, when coming home/unlocking the car still fogs only lit up.
I gave up in the end, it's good as it, but I'd like to have headlights on with coming home function.
Old 8th April 2014, 07:01 AM
ScottD3's Avatar
I was looking at some VCDS coding for my Dad's touareg and apparently you can do a 8 gun salute.
Its every light light at the front turning on when unlocking or locking the car.
[center]
06 3.0TDI Quattro:
Options:
Old 8th April 2014, 07:24 AM
Yeah, even Passats years ago had a dipped beam function when coming/leaving home
Where did you found this coding on your Dad's car??
Go to the same module, click coding and all the info/options about the coding on this car (8) should pop out in a window, see if there is anything you can change
Old 8th April 2014, 07:40 AM
That seems stupid.
You will always hap dipped beam - it just means the lights won't resume on main beam (high beam) if the stalk is left in the main beam position when auto lights come back on.
