I suspect some modification to the tunnel will be needed to give you somewhere to put the clutch pedal - depends if the manual box is all that much narrower than the auto, given there'll be a slave cylinder somewhere in the mix
A remote clutch cylinder in the scuttle area should be doable - there's a fair bit of space really, just not next to the brake master cylinder I think from looking at manual rs6 conversions there are some decent challenges to overcome but a decent fabricator should be able to use elements of a left hand drive pedal box and the existing auto one to make something that works
Need to have another think about it tonight |
In the past I recall seeing various LHD conversions that used mechanical linkages to transfer brake and clutch movement across to cylinders on the left.
Sounds like a fair bit of creativity will be required.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
Mmm thats also an interesting idea. The B5/C5 works like that.
I need to buy a spare one I think |
Goran on this forum had started to work out a lot of details but ended up buying a LHD S8 D2 from Germany instead but I think he would still have a lot of the information, and some of the parts he was collecting went across to ConanTheLibrarian on here for his future use in the supercharged wide body S8 D2
I wonder if there is electronic drive by wire clutch control available that could be used. Or mayby a samll master cylinder from motorbike or 2 in parallel if 1 is not pumping enough fluid.
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 12th July 2016 at 07:09 PM. |
The 0A3 is 30mm longer than the 01E so the proper manual prop won't fit either. I'll probably have a local company make up a spacer.
It also has 100mm tripod flanges instead of 130s so I'm thinking C6 driveshafts. The track is different by only 20mm between D2 and C6 so tripods should have room for that. Worth a try since they are cheap. If they're too long then B6 with spacers. The 0A3 is quite bulky compared to the 01E, but only a couple of Kg heavier. Still much smaller than the 5HP24A though and 50Kg lighter I think I may have seen Goran's thread on his plan - some quite useful info. I wondered why it never reached a conclusion! |
