D2 - Interior Seats, dashboards, plastics, ventilation everything inside the cabin |
#41
IIRC when I fitted my Vavona door switch panels they looked like a painted thin metal sheet folded over the plastic moulding. I just touched up scratches with lacquer and re-painted the dark door switch holes with matt black paint (not very well ). Another minor point to note is to be careful of the lugs when removing the lower sections, which you do first. This is to avoid cracks or breaks. IIRC the rear door has 2 main lugs that catch on the door panel, on the front and rear "upright" edges (plus lugs that intersect with the upper section near the screw fixings). And there's a set of smaller lugs on the top edge that pop open easily. So to remove those you prise out gently along the bottom and up the sides until it release those 3 sides, then pop out the top lugs and wiggle it out horizontally to disconnect from the upper section. Note that the bottom edge has no lugs at all, it's just an easy place to get a tool in and work it round to the lugs on the sides. The front lower sections are similar but a bit trickier. One of the "upright" lugs is larger than the other, so the smaller one needs popping out first. If you buy new ones you'll hopefully see which way round it is first. Once the lower sections are out and the 2 screws then exposed are removed the upper sections wiggle out fairly easily. They are retained with big lugs on the cabin side and smaller metal clips on the outer edge. The easiest way to get them out is to lift and release the outer edge first, just by pushing up from below using the handgrip. Once tilted inwards they pretty much lift straight out.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
#42
That's just what they are.
#43
Do you have surplus myrtle/platinum trims? And exactly what is available for £73.99 - complete upper trims with myrtle over platinum?
#44
Adrian currently has painted (purple) plastic trim for the door switch panels that he is changing to Myrtle, so no spares presumably.
#45
£73.79+vat buys you any one wood trim from TPS
#46
Can you get a discount at TPS? I might bite the bullet and go for all 4 if I can get myrtle on platinum
#47
If you really do need platinum I can supply all the part numbers you need The Mertyle/Swing options are sold out of drivers door ones With lower bits as well it's about £400.....
#48
I actually need 'silver grey' but as that's a special colour, I think platinum is nearest. So Myrtle/Platinum would be the nearest as platinum is lighter than swing I think
#49
It is - platinum in the pics I've posted is the colour of the surround for the door pull handle and the memory seat surround
From what I can work out the full range of PR codes for interior wood trims are: PR code - name of wood finish - name of door switch surround wood finish - lower trim colour options 5MG - burr walnut - nut brown switch trims with either soul/blues/swing/jazz/platinum/aqua/tango/twist 5ME - Vavona amber high gloss - Bernstein with blues/jazz/aqua/tango/twist OR amber wood with platinum 5MW - Dark Myrtle - myrtle with soul/swing/jazz/tango 5MX - light birds eye maple - birds eye maple with platinum/soul/blues/swing/aqua/twist Looking again at the pics I was sent of the £50 set which appeared to be platinum, I suspect they were actually birds eye maple finish as I can see code EZD written in 1 picture, which corresponds to that option. Having typed all that hopefully when you look at the attached Etka print outs, which were too confusing for the TPS bloke I spoke to to deal with, it makes it easier to follow!
#50
Just for info these are the pics of the set I was offered for 50 quid - you can see why it's a struggle to figure out what they are!
