Old 16th August 2014, 02:49 PM
mannyo mannyo is offline
Default D3 coding gear display on Pre facelift
I've seen this on some FL A8s where the current get in use when in D or S is displayed to the right of PRNDS on the bottom line. My PF D3 only has PRNDS, so the question is can I code the Auto Trans module to display the current gear.
I know its not going to be in coding, but I believe its going to be one of the adaption channels possibly.
Manny
Past
Old 16th August 2014, 05:02 PM
I think that's a function of the dash itself and not the TCU.
Old 18th August 2014, 08:06 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I have read somewhere about coding this but can't remember where.
I'll have another look and if I find it I'll let you know.
Got a feeling its more to do with the cluster than the box.
[center]
06 3.0TDI Quattro:
Options:
Old 18th August 2014, 03:21 PM
I found something about alternative gear display but it does not apply to PF D3's, as it needs to be done with the long coding helper. The PF D3 does not use long coding in the instruments or auto trans module.
Manny
Past
Old 19th August 2014, 07:21 AM
ScottD3's Avatar
I'll double check my coding for you.
I got what you are after but can't remember seeing the long coding options.
[center]
06 3.0TDI Quattro:
Options:
