Variable Intake Manifold Links
I did a quick search on the forums but couldn't find anything on this topic so I thought I'd post what I've just done...
A few months back whilst I was cleaning the engine, I noticed that one of the plastic links that controls the variable intake manifold was clean broken. So I started the search for how to fix as Audi Aust said that there is no fix, only a replacement manifold. The SSP clearly states this also - at $4,500 I figured that there was a better ways to spend the $$! Anyway, cut along story short, I found some parts in the USA from a supplier called Gruven Parts. They make a replacement arm in Al. Given that the internal 'flaps' are plastic, it means that they become the weakest link and not the linkages. The Audi SSP states that they work by varying the intake length to improve low end torque and top end power. The way it should work is as follows: With engine off, the arms are under spring tension and therefore the internal flap allows the 'short' intake length. Upon starting and engine at idle, the vacuum pulls the arms down thereby making the length 'long'. It stays like this till 4,480rpm when the solenoid trips and releases the vacuum, thereby allowing the shorter run. In 'long' length, better torque at lower rpm, in 'short' length after 4,480rpm, better power. For me, with a broken linkage, I had one cylinder bank running in 'short' length all the time, hence under 4,480rpm I had one bank in 'long' and in 'short', effectively inhibiting low end torque. After fitting the new links, I did actually notice a better response in low end torque, albeit not a huge gain. Well made parts and took a few mins to install, here's a pic of before and after. Before: After: Interestingly, whilst rummaging through the SSP, I also found that on WOT when revs swing past 3,000rpm, another flap opens in the air box to take additional air from the engine compartment! So darn complex!! But oh so smart!! Cheers
A8 4.2 S
There's certainly been discussion here about that exact topic, but being a D2 driver I didn't study it in detail or recall exactly where it was posted.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
There's threads about these arms in the d2 section, but probably not such a common failure on the d3 yet - nice to see some installed pics too
Am I right it's only the 40-valve engine in the D2 that use these?
(I'm PF 32-valve and "managing" with "only" 340hp)
Nope.. the PF has them too. Slightly different lenghts though.
Not sure if I've heard of the 32v having a problem with breakages though.
Looks like a nice piece of sturdy engineering
Though if Audi had made such a sturdy part it would have cost them an extra 20p per car
. Nite Blue 3.0L SE Quattro Last edited by 47p2; 11th March 2012 at 10:40 AM. |
What is SSP & WOT???
Statutory Sick Pay |
All things relative, they cost me about $70 AUS. I Imagine the Audi engineers saying to themselves, "well here's a way to make money on parts, we'll make a really weak part that can only be fixed by buying a whole new intake assembly". As you say, it would've cost them next to nix to produce a quality part. Seems in complete contrast to the rest of build really doesn't it.
A8 4.2 S
