Old 22nd May 2018, 09:36 AM
roberto's Avatar
roberto roberto is offline
Default A8 D3 sports seat (for my man cave) Wiring up ?
bought a pair of seats as above
i want to steel frame mount them together
but 1st
how do i wire them up to work on all buttons ?
the D2 ones are simple but not these i think they are can-bus wired
not sure how
any ideas please ?
do i need to post in D3 electrics ?
thanks
Old 22nd May 2018, 01:51 PM
Hmmm.
D3 seats have component protection. 'Essential' seat adjustments may well work, but others won't.
D2 ones are a simple single +12V feed and away you go.....
Old 22nd May 2018, 03:10 PM
Yup
Old 23rd May 2018, 02:10 AM
roberto's Avatar
CP will kick in if the authorisation module tells it to. Since it's not connect to any other subsystems you may be lucky. Hook it up to some power. Pins D11 & C11 are T30. Pins D12 & C12 are T31.
Doubt it's that simple but worth a first try.
what are these please as i am no lecky
Old 23rd May 2018, 09:13 AM
roberto's Avatar
Thankyou i will proceed with caution
Old 24th May 2018, 07:37 PM
roberto's Avatar
Default update
well i was a bit scared as i am no motor electrician
so i gave sharkperformance in mansfield a call as i do some work for them
Ben sorted it within 5 mins, 2 12v feeds + 1 earth
done
nothing else mattered
im so chuffed they work great..
no component protection or canbus problems
almost as simple as D2 seats
thanks all for your advice
Old 24th May 2018, 08:25 PM
Good to know. Thanks for the update
Matt
