Old 18th March 2017, 07:49 AM
Default "There is congestion on your route......
.....an alternate route can not be recognised"
OVER AND OVER AND OVER AND OVER AND OVER AND OVER.
9 times last night over 2 miles! So I switch the Nav off. I don't actually need it most of the time, I just like the ETA showing for when the wife phones and asks!
So I am sure there is a simple way of switching her off? I also don't want to be left with the halfway house option that silences her but semi mutes the stereo for 10 secs, that is equally annoying when rocking out to Free Bird! Had a look at the manual but the answer isn't jumping out at me.
Overall I like the Audi system and am not a fan of using a secondary option, my iphone etc, as a solution.
Although...... Anyone use 'Waze'?
Old 18th March 2017, 09:33 AM
Press the Nav button to enter Nav - then press set up then choose "voice guidance off" from the settings. I don't use it at all on d3's as I have customers in the cars who don't want to hear it!
Old 18th March 2017, 11:29 AM
Thank you, will give it a go.
Old 18th March 2017, 04:46 PM
Free Bird should NEVER be muted or in any way interrupted
I've had similar issues since replacing the original disk
Old 18th March 2017, 07:52 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Never had this problem. And never have voice instructions on, at least in the UK. Sometimes abroad I have it on, cos it isn't talking at me, and repeating every 10 seconds.
2007 Mini Cooper S R56
Old 20th March 2017, 07:38 PM
So, my voice guidance settings were already off. "Turn left, turn right" etc.
The 'trying to re route you' announcements must be another setting, I will continue the search! I have the voice turned all the way down, hence 10 secs of quiet whenever an announcement should be happening...........
Old 20th March 2017, 08:14 PM
I don't have the problem you describe, I have the vocal cues turned off, and not the volume turned down.
By turning the volume down, you have still left in place the instruction to the stereo to reduce volume which enables your (now muted) voice guidance to be heard.
Try turning off the voice instructions in the MMI
Old 21st March 2017, 01:16 PM
Wow, I have NEVER had this in >5 years of ownership and use it a lot.
Is it dynamic route guidance settings?
Old 21st March 2017, 02:20 PM
Maybe that is it, good suggestion!
It did it again today, letting me know over and over how busy it was in the centre of Wandsworth but that it doesn't have any other route ideas!
I tried to capture it on my phone but obviously not able to as I'm driving!
Old 22nd March 2017, 06:47 AM
Johnmed's Avatar
I have dynamic route enabled and voice set to OFF Never had this either.
OP, do you have an iPhone or something attached? Only ask as if on mute the iPhone quitens briefly when you receive a notification.
