Old 13th September 2017, 10:38 AM
Johnmed's Avatar
Johnmed Johnmed is offline
Good plan. I think it may be environmental, with Ray and I being fairly close geographically. I hope, more than think...
2007 Mini Cooper S R56
Old 13th September 2017, 10:50 AM
Found this map of DAB TX stations. It dates 2011 but it resembles my experience of where I can't pick up DAB in Norfolk and Suffolk.
Edit:
This is also good:
http://www.ukdigitalradio.com/covera...ttransmitters/
Matt
Old 13th September 2017, 01:11 PM
Oh Dear,
I don't have address 0F.
I retro fitted the DAB.
I have Address 56 i.e.
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 B
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 304DV047586477
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 316939F1A8CC37A9D05-8064
No fault code found.
I'll have a look at my screen later when I get back to the 8.
Old 13th September 2017, 01:15 PM
Oh Dear,
Probably need to select it in the CAN installation list.
Matt
Old 13th September 2017, 01:58 PM
Johnmed's Avatar
Ok, hope this helps someone. My issue is with the National stations. I enabled the signal strength readout and have 4 for the stations I like to listen to, and the other local commercial stations I have 7.
Don’t know why, or why it has recently worsened. But at least I can visually monitor the strength of the National stations now when out and about.
ID:	16994   Click image for larger version
ID:	16995   Click image for larger version
ID:	16996   Click image for larger version
ID:	16997   Click image for larger version
ID:	16998   Click image for larger version
Old 13th September 2017, 02:22 PM
All good info.
I have 7 on BBC 2 but only 4 on Smooth. These are the national stations, didn't think to check the locals, I'll do that later.
My error, my fault, I was looking at a very old log.
Just done another read and I do have 0F
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276V7500368
Coding: 0000001
Shop #: WSC 02319 758 00200
VCID: 2447C0A5E73E9266CE-8070
I'm on grandfathers taxi today so I'd better head out.
Whilst collecting the little ones I had a play with the result that all, National and Local, vary mainly between 4 and 7 as I'm travelling.
Friday I'm driving down to Chepstow so I'll try and keep my eye on it then.
I know why I have problems when parked outside our house, it and the mill behind us are in direct line with the Winter Hill transmitter which from Matts information is the main for this area.
Old 19th September 2017, 04:23 PM
audifin audifin is offline
FWIW mine was like that when I bought the car, i.e. only very few channels worked and only in very specific locations. Turned out the Amp was broken - although I couldn't find any way to verify this. But I bought a new second hand one and it works perfectly.
Old 19th September 2017, 09:12 PM
Signal strength is not really relevant with digital reception.
It is signal quality (SNR) that needs to be monitored.
Old 20th September 2017, 12:13 AM
Sorry for the delay in updating this thread, personal problems have distracted me over the last few days.
Drove to Chepstow last Friday, spent the weekend there and returned on Sunday.
The good news is that I had Smooth Easy playing all the time and it worked perfectly. Really surprised that the only time it weakened, but not enough to swap automatically to FM, was in the dip near Chepstow Parish Church.
I do not really understand this sudden improvement. Last week I did remove the aerial preamplifier to take a photograph of it alongside my original preamp, then replaced it in the car.
So I guess simply taking the preamp for a walk away from the car for ten minutes then refitting it might just resolve the reception problems for others.
Remember I am only a simple old fogey and the silly easy fixes suit me down to the ground.
Old 21st January 2018, 04:00 PM
Johnmed's Avatar
Small update.
I removed the power to my dashcam and the reception seems to be much better. I’ll not say it’s fixed until I’ve driven the car a bit more than I’ve had a chance to today.
