Belt or chain?
No I'm not talking 50 shades of grey but engines.
Seem to be finding conflicting answers, got a 4.2 v8 A8 in a pre face-lift d2 Can anyone confirm if it's a timing belt or chain Many thanks Lee |
Almost certainly a belt
Timing belt All D2s have belts, as do early D3s.
There are chains in the heads to link the two cams together but on a PF you don't need to worry about them To swap the belt needs special tools (obviously). I have the crank holding tool, but I don't have the cam alignment tools which go in the back of the heads. I'm not sure who has a set of these tbh: |
Ahh many thanks, just re checked what I was looking at and appears it was the 4.2 out of an a4.
Thanks for the help, any suggestions for interval on replacement? TIA |
S4 was the first chain driven v8, so that makes sense
No idea on interval I’m afraid...... but I am sure someone else will advise! |
80K or five years, whichever is soonest.
Always change the hydraulic damper / tensioner. I've seen more engines killed by failed tensioners than anything else. I do the water pump and thermostat every other belt. Genuine pumps are <£100 exchange from TPS. |
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
