Remote control batteries
Hi Guys & Girls,
Could someone please confirm how many batteries are in the D2 remote key fob. I have just changed my Central locking pump, which now only works on the key in the lock, but not the remote. Thought I would change the batteries. On investigation one set of keys has two batteries, the 2nd set only had one battery in it. Would you also know what battery type/number I should replace with. Is there a set process to go through to get the key remote to work again. Thanks David
2002 S8 Final Edition, Avus Silver with Red leather interior Guildford, Surrey Tiptronic with Sport mode button. Sony rear entertainment package. Bose sound system. Audi Navigation Plus. 20 inch Final Edition alloys Full Cat Back Stainless Milltek exhaust, giving a great V8 burble : 1997 A8 Quattro Sport - Now sold when S8 FE purchased |
x2 3v coincell, dont know the code.
1620 is the battery code for mine - about 1cm diameter - just bought some Duracell ones off ebay for next to nothing incl delivery
I wish all batteries lasted 15 years !! Ive got Duracell rechargables for my petzl head-torch i use all the time, but they seriously loose their stamina after what doesn't seem like loads of charges.
Thanks Guys,
How do I reset the remote to read the new central locking pump should I need to after replacing batteries?. Thanks David
You need at least 2 keys:
1.Switch ignition on and leave the key in ignition 2.Lock vehicle from outside with the key to be adapted by way of the driver's lock door. 3.Within 5 seconds press "unlock" key of remote key until next memory position is reached (so it will be once for 1st key, twice for second key etc). Each time the button is pressed the hazard lights will flash to confirm. 4.Wait 5 seconds. 5.Now press the "unlock" key again to confirm the matching process. This vehicle key is now saved and the central locking must unlock. You can then proceed to next key and save it in another memory position.
Thanks Ainarssems
OK, So I met up with Barzya8 yesterday and we tried to sort out his keys. We tried Ainarssems method, a similar method found on-line and then using VCDS went into the central locking to try the process in the VCDS Wiki here.
Unfortunately there was no reading in any Group. There should be! Anyone any ideas? CtL
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
Hi Conan,
Just to let you know I have managed to code both sets of keys using the following procedure. Both remotes now work fine except there in no horn toot when locking. Something I can live without. AUDI A8/S8 (1997-1999) Procedure AUDI A8/S8: Programming the Key Fob Remote Control Programming (1997 ON) Procedure 1. Switch Ignition ON and leave the key in the ignition. 2. Mechanically lock the vehicle using the Drivers door using a second key. 3. Using the remote control press the Unlock button once, and the horn will sound once. 4. Wait 6 seconds and press the unlock button once to activate the coding procedure. The remote control will now be programmed. NOTE : When performing programming on additional remotes the procedure is the same, except you press the unlock button 2, 3 or 4 times for the different remote. For example : If programming 2 remotes press the unlock button twice with a 1 second interval between each press, repeat for 3 and 4 remotes. 5. Switch Ignition OFF. 6. Remove key from ignition and check for operation. 7. The coding procedure can be repeated up to 4 times for additional remotes. 8. The ignition must be switched OFF between programming each remote control. Thanks for your efforts & help at yesterdays Regional meet Should this be added to a sticky?? David
That is something you code separately, using VCDS or equivalent, via the Central Locking module (35).
There's a thread (probably several) with the coding described; I know I added a detailed breakdown of the many security options in there myself.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 30th March 2015 at 03:19 PM. |
