Old 17th May 2020, 08:13 PM
I made a tool from metal bar and 2 bolts, M6 I think, when I was doing it.
Old 18th May 2020, 02:44 PM
Audifan Audifan is offline
Part of my post yesterday
.....I don't have the special tool to remove the fuel sender cap or have a way to make my own tool.....
I don't have a welder and don't have a drill press. So I can't take a metal bar to weld two bolts to it or take a metal bar and drill two holes to fit the bolts though. I guess I'm going to have to buy the tool.
Old 18th May 2020, 03:59 PM
This is what I use:
Lube sometimes helps too - I tend not to use WD40 on o-rings or plastic, but some sort of light oil maintenance spray which is thin enough to soak down the cracks would help.
Old 18th May 2020, 07:10 PM
I used cordless drill and and bolts with nuts,
Old 19th May 2020, 08:31 AM
C4R 100N's Avatar
C4R 100N C4R 100N is offline
This solution cost me a few dollars from a hardware shop. No tools or welding required - just a measurement or two. Ok, I lied - I did have to file the channels in the angled metal a little.
Did you read the notes that I posted?
Click here
1998 D2 S8 Jaspis Green
Old 21st May 2020, 11:40 PM
I did read your notes and that part must have slipped through my mind lol. I was laying in the trunk on my side when I read it and probably didn't absorb that info as I was frustrated with trying the pliers method like in that video. I ended up buying long 90 degree needle nose pliers that I will use this weekend. The nice thing about the 90 degree needle nose pliers that I bought have a flat surface that I can push down with my other hand while trying to turn that cap.
Old 29th June 2020, 08:50 PM
I ordered a new fuel pump to replace the new fuel pump that I broke and finally got the fuel pump assembly reinstalled.
How important is to have this locking tab completely square? Sorry I wasn't able to get a clear picture of this locking tab so it's a little hard to see but it's not completely square. I can't get the top half to turn anymore to the left to get it square.
How important is to replace the rubber o ring that's for the round electrical plug at the top of the fuel pump assembly?
New fuel pump installed and installed new ear clamps.
The fuel pump assembly is ready to go back into the car.
Name:	fp assembly 1.jpg
ID:	24406   Click image for larger version
Name:	fp assembly 2.jpg
ID:	24407   Click image for larger version
Name:	fp assembly 3.jpg
ID:	24408   Click image for larger version
Name:	fp assembly 4.jpg
Last edited by Audifan; 9th November 2020 at 10:13 PM. Reason: switched pictures to attachment
Old 1st July 2020, 01:05 AM
27litres's Avatar
27litres 27litres is offline
O-ring on the electrical connector is not super critical. It doesn't seal anything in the tank.
It's mainly there to seal the connector from the world around the tank (tank just hangs below the car, and can be subject to water spray, road grime etc).
I don't like it in the video (in vicinity of 10:30) when he says to just pull the pump straight out of the tank.
NO YOU DON'T!
I'll keep saying this: "it corkscrews out"!
Pulling it straight out puts unnecessary strain on and can damage the hoses.
I made a crack on the main high pressure hose (from the pump to the top of the housing) worse on mine by initially following that advice. On the third pull out of the tank (initially thought I hadn't seated it properly), I had my technique sorted and also found the problem!
You don't need your own marks on the housing either, there's a small triangle at about 4 or 5 o'clock on the housing top that lines up with another on on the tank top.
The big plastic ring nut that holds it all in and seals the tank gets tightened "tight". Mark it of you want. I didn't.
I'll also confirm Pauls advice (of mine) that you don't overtighten the long bolt on installation.
The nut is captive in a weakish plastic housing on the bottom of the in-tank receiver under where the metal-rubber gasket mates, and its very easy to overtighten and end up with it spinning in the housing. Not easy or cheap to solve, so don't do it!
I'm sure Audi has a torque spec for this, but if you have good feel when tightening, you can tighten the long bolt by hand until the rubber starts to bind/compress on the metal rubber gasket. At this point put your spanner on it and gently tighten until the "squishyness" of the rubber becomes solid hard. Stop there - you have now squashed the rubber flat onto the metal part of the gasket, and that is as good a seal as you are going to get. Any tighter risks disaster, and won't achieve anything.
ID:	23557   Click image for larger version
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 5th July 2020, 05:04 PM
I ran into another issue during my fuel pump job. For some odd reason I can't get the banjo fuel line square when I'm trying to start threading in the banjo bolt . Has anyone run into this problem?
Name:	fp assembly 5.jpg
Last edited by Audifan; 9th November 2020 at 10:07 PM. Reason: switched picture to attachment
Old 5th July 2020, 05:17 PM
Yeah thats tricky to line up. I find its easier to push the union down on to the pump body while getting the banjo to catch as thats the best chance of getting it parallel with the threads.
One other thing is to make sure the ribs on the black plastic nut aren't fouling the hard line, as they can stop it sitting flat. It looks like you may have one sitting right under the hard line, in which case just try to move the nut 1/4" way or the other to give a bit more room.
