Old 23rd April 2017, 11:08 AM
oldnick oldnick is offline
gas in fuel rail but plugs dry when it turns over ?
got to be not enough pressure whatever else might stop it starting
ergo MJ has to be correct ...take out the new pump and reseat the old one maybe...it worked , didn't it ?are you sure you fitted the VDO one with the extra pickup tube ?
Old 25th April 2017, 03:50 AM
27litres's Avatar
27litres 27litres is offline
Fuel at the rail - where are you measuring it?
You need to measure for flow on the low pressure return line after the pressure regulator.
Measuring it on the supply line is worthless.
Low pressure could be an indication of a split line - one of the rubber hoses on the fuel pump assembly (in tank) of mine was split and wouldn't pressurise the rail - kept me guessing for a couple of days that one!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
