Old 5th June 2021, 10:18 PM
Deckard's Avatar
Deckard Deckard is offline
Why do you call it Botangs hole and does it eventually let rain water in from the road?
Current ride
[b]'06 MX-5
Past rides
'07 Boxster
'08 Mini Cooper S
'17 BMW i3
'04 BMW 535d
'97 Porsche 993 C2S
'72 Porsche 911 2.4S
'90ish Fiat X19
Old 6th June 2021, 07:33 AM
Because a forum user called Botang found it Yes, eventually (and already on most D2s) the tape dries up and peels away from the hole and lets rainwater in (running off the screen) which drips through the indicator relay in to the main relay box.
Old 6th June 2021, 07:52 PM
Finished off preparing the engine bay today. prior to putting the engine back in. I started by converting the stud by the starter junction to a rivnut. This always snaps because it has a steel nut on an M6 aluminium stud but I'm used to dealing with it now.
Pilot drill the stump
Drill to 9mm
Rivnut inserted
I also put rivnuts in the usual places in the bay
This stud is always snapped when the gearbox has been removed. I'm not sure why, but I managed to get a snap washer on the stump so it doesn't rattle
Engine ready to go back in:
and back in
I got most of the gubbins underneath hooked up this evening, and I can work on the wiring and plumbing tomorrow
ID:	26561   Click image for larger version
ID:	26562   Click image for larger version
ID:	26563   Click image for larger version
ID:	26564   Click image for larger version
ID:	26565   Click image for larger version
ID:	26566   Click image for larger version
ID:	26567   Click image for larger version
Old 6th June 2021, 09:08 PM
S81 S81 is offline
As a matter of interest would it be fair to say that after this level of refurbishment the car should be good for another 15 to 20 years ( assuming it gets suitable on going servicing)?
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 7th June 2021, 09:55 AM
Markiii Markiii is offline
im impressed with how well the paint in the engine bay seems to have held up to the years
Old 7th June 2021, 11:00 AM
Stuff like the engine should be yes. Control arms tend to last 5-10 years. Gearboxes can obviously expire at random, but this one is relatively young so should have plenty more years in it. The rear subframe / suspension will need doing at some point (they all do). So, the parts which have been worked on should last at least until the dino squeezings run out, but others will still need R&R in due course.
Surprisingly well since its unlacquered in FL2s, although the darker colours tend to clean up a bit better as they don't stain so easily.
Old 7th June 2021, 08:30 PM
I finished off under the car so started on wiring and plumbing
I put the upper arms and struts back in so I didn't have to move the coolant pipes out of the way later
Worth noting that the Meyle arms come with the incorrect hardware in some locations, notably the bolt for the upper rear arm is too short and won't engage with the locking portion of the nut
and the lower front arm for steel uprights comes with a balljoint nut for aluminium uprights. I need to see if the proper nut is still available.
ID:	26574   Click image for larger version
ID:	26575   Click image for larger version
ID:	26576   Click image for larger version
ID:	26577   Click image for larger version
ID:	26578   Click image for larger version
ID:	26579   Click image for larger version
ID:	26580   Click image for larger version
Old 8th June 2021, 03:37 PM
Ronin Ronin is offline
I have meyle on steel uprights. Is this just OCD or a proper safety issue?
Old 8th June 2021, 04:05 PM
Its actually not a big problem if the larger nut actually goes on the front lower arm as there is room for it underneath. I've been led astray by this one having the nuts in the wrong place!
You can see the shiny mark here where the wrong nut which came off had been interfering. It might just bend the washer when its torqued, but thats not right either
The steel uprights are supposed to have two of the small ones, but there is room for the larger one on the lower front so its not a problem if the surface is clean and flat and the nuts go on the arms with which they were supplied.
The proper ones are still available for £5 each so I will fit those anyway.
ID:	26582   Click image for larger version
Old 8th June 2021, 04:13 PM
Default Nuts....
I had the same issue when tightening my nuts up
Was tempted to use the old ones, but then machined down the nut "flange". Think I may have to go back and re-visit this.
Paul
Gosport UK
________________________
Audi S8 2002 FE Avus Silver / Extended Red Leather.
Daily Driver: BMW 3 series GT - Just more practical for my camping trips!
