Old 12th May 2015, 09:28 AM
Ricky22buk Ricky22buk is offline
Default Gearbox Filter ?
Just curious is there any savings by buying the gearbox filter and or kit for my 2002 S8 anywhere other than from Audi ? Anyone even know the prices or part numbers off the top of their head ?
Also do I remember reading on here that there are two different filters or am I dreaming ?
Thx !!!!!
Old 12th May 2015, 10:07 AM
HPsauce HPsauce is online now
IIRC there are two different lengths of filter, you need to get the right one obviously.
I left it to my garage to get the parts, which I think was from Audi.
Old 15th May 2015, 10:54 AM
Dave McB Dave McB is offline
Accdording to Mackie's - theres 2 options.
One has the filter tray 2mm deeper than the other one. If the incorrect one is fitted, the box can be starved of oil and ruined. (Heard a horror story from the parts guy at mackies - someone had put the wrong filter on a box that they serviced and Mackies got the car in with the after effects)
You need the gearbox serial number to ensure the correct one
Old 1st June 2015, 09:49 AM
I really should read the forum stickies before asking some questions. All info needed there !!!! Sorry !!!!!!
Parts Needed
01L-325-429-A Filter (see note below)
01L-325-443 Filter to Transmission Gasket/O-Ring
01L-321-371 Pan Gasket
01V-321-379 Fill Plug Sealing Washer
G-052-162-A2 ATF Fluid (have 8-9 quarts on hand, you might use a little less), use ONLY Audi fluid
NOTE: 01L-325-429 is the filter part number for model year 1997 A8's that came with a type DPZ transmission with a serial number of 001891 or less.
01L-325-429-A is for all 1997 A8's with DPZ transmissions with serial numbers greater than 001892, DSM type transmissions and DTE transmissions. The DTE transmission was supplied on later 97's and all 98-03 A8's.
The transmission nameplate can be found on the bottom of the transmission just forward of the pan.
