D3 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here |
Tpms help please, new sensors fitted
Alright lads.
Had new tyres put on today so changed the old dead tpms units for new ones. Im having trouble getting them to register. Can someone do me an idiots guide to enabling and coding in vcds pretty please. This is what i have at the mo showing Lovage xxx |
Coding on that screen is fine, you need to check coding in 17 instruments first pair of non 0 digits should be 48
Also check the coding in control head if you are missing the menu item from the systems dialogue on the mmi Once you have that all sorted go into the tyre pressure menu and choose initialise then go for a decent drive Good luck
Del |
Yep all that is good.
So its a case of give it a drive? Came back across town once wheels were done. Should i hit the dual cabbageway later? Its telling me to put key in and turn ignition on to configure the system, could it be do that and wait for 5 or 10 mins? |
From starting the process when I did mine yesterday it took a 15min approx drive to get it to register.
Del |
You changed yours again Del, or is initialising necessary after some activities? I'm still debating whether to have mine sorted when I fit the original wheels or just do without them.
Audi D3 S8 - 2007 - V10. B&O, Phantom Black, black and silver interior, and still completely standard with everything working as it should Audi TT - 2015 - Ultra |
Took the wellies off and fitted the running shoes back on so had to code it all back in Ron
Del |
Oh ok brilliant. Me being impatient then! Cheers Del.
