Old 24th October 2017, 04:27 PM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Gate opener lightly modified to accept input from PF blind switch
....Do like the batcave suggestion, my dad has nicknamed the car 'the batmobile' in the past
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 24th October 2017, 05:19 PM
Also did this some time ago:
http://forum.a8parts.co.uk/showthread.php?t=6501
Old 25th October 2017, 05:49 AM
Ameiseuk's Avatar
Yep, the FAAC remote I used was of a similar design. 2x coin cells inside it.
Swapped the 2 cells over to new ones so will last years for all the use it ever gets.
I wrapped the remote up and put a bit of velcro on the 'non button' side. Other half of the velcro is on the lower dash panel.
I can just reach above the accelerator pedal and detatch for battery replacement if ever needed
Daily drive:
Current 'Project':
2000 Audi S8 FL
www.whall.co.uk
Old 25th October 2017, 08:25 AM
Old 25th October 2017, 10:09 AM
Doesn't the remote fit through the switch mounting hole?
If so, to change batteries just pull it all out.
Old 25th October 2017, 03:36 PM
I was going to suggest number plate rotator
too late now
Old 26th October 2017, 11:35 AM
Ameiseuk's Avatar
Thought about a number plate rotator!
The remote is a very neat fit through the existing hole, feared I may trail wires off if it got wedged in so the velcro under dash route was a more future proof solution.
The newer FAAC remote is even bigger so if this one fails I can simply swap them over and continue
Future proofed!
Daily drive:
Current 'Project':
2000 Audi S8 FL
www.whall.co.uk
Old 26th October 2017, 11:54 AM
I'd have put a simple 2-pole connector (or two single ones) in that cable as well, probably down near the Velcro so the transmitter can easily be totally removed/replaced.
