broke my fuel pump
I wasn't careful when I was tightening the nut for my new fuel pump and snapped off one of the terminal post looks like I need to buy a new fuel pump
Last edited by Audifan; 9th November 2020 at 10:35 PM. Reason: switched pictures to attachment |
Maybe a stupid idea but if you're careful could you not try soldering the terminal to what remains of the stud? Your gonna scrap the pump now I guess so maybe worth a try.
or drill and tap it?
It's possible but I have no idea how far I can safely drill down into the broken stud on the fuel pump side. Also finding a small enough replacement stud to screw into the newly drilled hole and have it tapped out to receive new stud. |
Given where it is, the difficulty of replacing it, and the consequences of it failing, I would be inclined to just chalk that one down to experience and replace it.
The max torque for an M4 bolt is around 2Nm, or 17 inch-lbs so barely anything really. |
This is the nut for the negative post on the fuel pump and it looks like it has a nylon insert?
Here is my attempt at fixing my broken fuel pump stud. I was able to drill and tap the hole. I was able to get stainless steel screw, washer and nut for the repair. Unfortunately I wasn't able to get the hole drilled completely straight . Got the head cut off and now I'm wonder if this is going to be a problem as this is not sitting straight and could cause a problem? Quote:
Yeah I know it doesn't need to be super tight for that nut. I guess I was super excited that I finally got everything I needed to start putting my new fuel pump back together and was in a hurry and over tighten that nut and it snapped Last edited by Audifan; 9th November 2020 at 10:49 PM. Reason: switched pictures to attachment |
Could you use a spring washer to help with the offset?
Can you just ignore the offset by tightening two nuts together on the bolt, keeping clear of the body, rather than tightening the nut down onto the body? Maybe with a locking washer of some sort.....
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
^ What he said. 🙂
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
Thats a nyloc - the insert stops it loosening from vibration.
