Failed supply to LH Reverse light
My left reverse light has stopped working, right is OK.
No voltage to LH reverse bulb. Are they fused seperately? Any ideas please. I have had a look at the current flow diagrams and I get lost when back at the control unit.
I think this is component protection Ray. The thing knows it's been fitted with a non OEM screw.
2010 A8 SE Executive 4.2 FSI D4 2007 Mini Cooper S R56 2008 D3, gone, but not forgotten after 9 years and 90k. |
Do you think the LED bulbs may have caused the ECU to cut power to the bulb? I think it does the same for the number plate lights when certain LEDs are fitted.
Did you fit the resistors? |
John, Tony,
You do not realise how close you are to the possible problem. Earlier today whilst battling the bus full of school kids through traffic my mind started pondering and came up with the idea that maybe the non-OEM led had broken and shorting the supply to earth. The ECU theoretically should limit the current flow through it's short circuit protection system by dropping the supply voltage to the faulty bulb to virtually zero volts. This would match my symptoms so Sturday's first plan is to strip the inner left light unit and check the LED bulb. If it has gone short circuit then I guess the OEM filament bulbs are gonna have to be refitted. Shame really 'cos the light output of the LEDs is much better than the OEMs.
It's a real shame if it does end up being the LEDs, Ray.
If you haven't already, would you consider fitting the resistor, or even a bulb in series? |
Not that easy unfortunately.
A resistor in series would prevent the short circuit LED affecting the rest of the circuit (I have taken a link from the LH reverse light feed to operate my non-OEM camera) but would decrease the voltage available for the LED when working correctly. The extra resistor/bulb idea is to wire in parallel with the LED to fool the ECU into thinking that it is a normal bulb. The ECU thinks the lamp is open circuit because the LED draws much less current than the correct filament bulb. I use a parallel bulb in my sidelights for this and hide the extra bulb behind the headlight reflector. This has a problem if the LED fails open circuit you do not know without checking the lights the old fashioned way (walking round the car). If the LED dies short circuit then you have the type of problem I have now. The reverse light is a more major job 'cos you have to drop the boot lid lining etc. to get at it.
