Go Back   A8 Parts Forum > Our Other Audi Friends > TT/TTS/TTRS 8J
TT/TTS/TTRS 8J 2006 Onwards
Old 4th May 2022, 09:42 AM
Default Space saver tyre sizes
I have tried to work this out, but I’m a bear of very little brain on this topic (at least!).
I’m trying to find a second hand space saver wheel & tyre for my TTS. The current tyres are 255 35 19. Does anyone know what size of space saver I should look for (they nearly all seem to be on 18” rims)?
Similar difficulties with my wife’s mini (can I mention that here?) which has 175 65 15 tyres.
Thanks and respect to the smarter folk on this forum!
Old 4th May 2022, 09:46 AM
This chart may help: https://www.komwheel.com/understandi...aver-tyre-size
175/65R15 - is that an "old" mini?
Old 4th May 2022, 10:45 AM
Old 4th May 2022, 12:43 PM
Thanks guys. I knew there’d be smarter folk along quickly enough.
It’s a 2013 BMW mini, so the model before they became ‘maxis’!
Old 4th May 2022, 12:52 PM
As long as the shell has 5 studs, is there anything else that I need to consider?
Old 4th May 2022, 03:54 PM
It’s the model before they became ‘maxis’!
Indeed! Not a mini at all anymore - if the Beemer one was anyway .
I'd love to see a photo of the "real" mini, next to a "new" 4x4 mini-max, next to a "real" Maxi. I bet it's closer to the Maxi than the mini.
PS: apologies for the thread hijack!
Old 4th May 2022, 04:44 PM
I bet it’s bigger than the the old Maxi.
Old 4th May 2022, 04:57 PM
PCD presumably?
Old 4th May 2022, 05:21 PM
PCD (5x112) and centre bore (66.6). Early TTs were 5x100 and 57.1 so you'll need to make sure it comes from the correct generation
Old 4th May 2022, 07:38 PM
Thanks so, so much! I could have wasted a good few quid on the wrong wheel and tyre. Armed with this information, I might just get it right.
Should I limit my search to a VAG wheel, or will other makes be OK if they match this set of criteria?
