Old 31st May 2022, 12:52 PM
That's a good idea Mini-meet & detailing day
Old 31st May 2022, 01:30 PM
Especially looking forward to those photos (shallow, I know...)
Old 31st May 2022, 03:48 PM
We could rock up at Nicola's for a "washdown training session" Bert can take some shots (sans Scooby) and get some additional editorial stuff for his magazine. Win Win.
Paul
Gosport UK
________________________
Audi S8 2002 FE Avus Silver / Extended Red Leather.
Daily Driver: BMW 3 series GT - Just more practical for my camping trips!
Old 31st May 2022, 08:19 PM
The arb links are wrong on the standard D2 Meyle kit as well as the FE I'll fix this when its back from Nicola.
The driver's door trim strip was in a bad state - the aluminium is not recoverable, and its bent at both ends
Window frame out so I can change the strip
Bad one removed
Replacement fitted - I polished this one before putting it on
Shiny
Mirror before
and after
The front passenger window was oddly crunchy so I removed the frame to investigate. While it was off, I polished the trim on this side - this one came out fine
Very bizarre - the cable has somehow escaped from the pulley Its under the glass so not particulary easy to get to
Some fiddling and poking got it back on. The window slides up and down just fine so I'm not sure how the cable came off in the first place. It shows no inclination to come off again
The Allroad is broken (because Allroad) so Lilith is doing yard donkey duties and she is not impressed! A D2 moving another D2 like this is very hard to manuever. It would be much easier with something short like an A2
Conspicuously still not at Nicola's yet Just the left side doors to put back together and then it'll be off
ID:	28613   Click image for larger version
ID:	28614   Click image for larger version
ID:	28615   Click image for larger version
ID:	28616   Click image for larger version
ID:	28617   Click image for larger version
ID:	28618   Click image for larger version
ID:	28619   Click image for larger version
ID:	28620   Click image for larger version
ID:	28621   Click image for larger version
ID:	28623   Click image for larger version
ID:	28624   Click image for larger version
Old 3rd June 2022, 09:44 PM
GH77 GH77 is offline
Default Replacement fitted - I polished this one before putting it on
Loving this WITW . . . . as always!
Question on - "Replacement fitted - I polished this one before putting it on"
What's the recommended process & materials for polishing the D2 chrome (aluminium?) surround trims?
I know (through miserable 2x£165 Audi spend experience) that the D3 rear quarters are irrecoverable once milky. It is nice to no longer have bright white rear quarters at night tbf though. Almost worth the expense . . . .
I've always avoided going to work on the D2 shiny bits because I thought it was the same deal as D3. If not, I'll be glad to get to work!
2000 FL A8 3.7 QS - Turned 21 years old on 15th March 2021. Ming Blue - 175k miles. I love having a 90's car worthy of 90L of 98 RON! If only they still did 4* fully leaded!
2009 A8 4.2 FSi LWB - Marine Blue - 164k miles. Extras? Too many to list. But I do like the Rear Seat Entertainment . . . . . .
477k miles to the moon and back. 238k to go and between them they'll have made it!
Old 7th June 2022, 08:26 PM
Just catching up on Car SOS nonsense and it reminded me of a spray silvering process that might work for unrecoverable ‘chrome’ trim
This is the company they used:
http://www.chromespray.co.uk/
Might be worth a try with a set that’s well past it and see if it’s cost effective/looks right? I suspect you’d need to do a full set of trim or there’d be noticeable variation in finish
Old 7th June 2022, 09:45 PM
There is another product that I came across a couple of years ago called Hydrochrome, but both products are quite expensive (even the 'basic' setup), so they're not the sort of thing an individual would purchase just for their own car. They both seem geared towards a full time business concern.
Old 8th June 2022, 06:30 AM
I have seen the silver nitrate products - you can buy the solution on its own relatively cheaply. I was looking at one the other day which is activated by a flame and goes from clear to chrome-effect. They look good on a nice smooth substrate, but when the anodising fails on the D2 parts they go like sandpaper. The silver nitrate coatings would just make shiny sandpaper in that case. You'd have to chemically remove the remaining anodising to bare aluminium, then sand and polish it to a perfect smooth finish (same as you do for actual chrome), at which point the silver nitrate is moot anyway since you could just polish the aluminium. The silver nitrate needs lacquering over the top to protect it as well so another extra step.
Indeed so. The amount of time this would take currently makes it cost prohibitive - it would be several thousand in labour just on brightwork. I can't see that being viable at the moment tbh.
I am planning on doing a full set in gloss black for my S8, which is going to be fairly labour-intensive, although doesn't require the full polish that silver nitrate would. It's probably going to be blasted and powder-coated. I'll report back on how long that all takes.
Old 8th June 2022, 08:36 AM
sarg sarg is offline
I saw that programme too, have their website saved in my bookmarks for 'another day'
2019 BMW M5 (my daily driver)
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 8th June 2022, 10:25 AM
I wonder how well that would work on a prepped front and rear screen trim surround?
Paul
Gosport UK
