Old 8th June 2022, 03:07 PM
What did you use to polish the mirrors?
Old 11th June 2022, 08:10 PM
Guess what is back from Nicola's? Its soooo shiny!
The gloss levels on this one are amazing, enhanced by the pearl in the paint I think.
We're both very pleased with how this turned out. It looks amazing with the diamond cut wheels and recovered brightwork
ID:	28638   Click image for larger version
ID:	28639   Click image for larger version
ID:	28640   Click image for larger version
ID:	28641   Click image for larger version
ID:	28642   Click image for larger version
ID:	28643   Click image for larger version
ID:	28644   Click image for larger version
Old 11th June 2022, 08:21 PM
I have a collection of metal polishes and heavy-cut compounds, but the key is the Rupes 70mm wool pad on a miniature rotary polisher. The wool pads really cut through the contamination on the surface more than anything else I've found.
Having got the car back to the workshop, I wasted no time taking it apart again
Stripping the rear suspension for new bushes
The subframe is a little crusty but not terrible, and the bushes are still intact, so this will stay in place for now. I'm going to try polyurethane bushings on my grey S8 shortly and see how it responds. If its acceptable then the subframe refurbs may begin again, since the Lemforder D3 bushes are out of stock everywhere.
Toast
and new
The diff was leaking badly from both output flanges with gear oil everywhere. After a clean, I pulled the driveshaft which is trivial with the hub etc off.
Loosening the centre bolt
The seal was clearly leaking badly
Removed and cleaned up
New seal in, flange cleaned up, and refitted
New tie rod and re-bushed lower arm back on.
ID:	28646   Click image for larger version
ID:	28647   Click image for larger version
ID:	28648   Click image for larger version
ID:	28649   Click image for larger version
ID:	28650   Click image for larger version
ID:	28651   Click image for larger version
ID:	28652   Click image for larger version
ID:	28653   Click image for larger version
ID:	28654   Click image for larger version
Old 11th June 2022, 09:00 PM
Wow!
That Irish Green Pearl paint looks just incredible! You do have to see it in bright sun to really appreciate it though.
And brand new OEM centre caps straight out of the packaging, so glad I bought those!
Old 12th June 2022, 06:24 AM
Amazing transformation....
The colour combinations are spot on.
Paul
Gosport UK
________________________
Audi S8 2002 FE Avus Silver / Extended Red Leather.
Daily Driver: BMW 3 series GT - Just more practical for my camping trips!
Old 12th June 2022, 04:28 PM
Markiii Markiii is offline
very nice
Old 12th June 2022, 04:50 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Absolutely stunning
2016 S5 Coupe Black Edition - Ibis White
Old 12th June 2022, 06:38 PM
Gorgeous. No other word for it. Great job
Old 12th June 2022, 08:09 PM
More on the rear suspension today.
Hub bushes in
Right side back together
The left side diff seal is a tad harder to get to as the exhaust is in the way, but thats easy enough to take off rather than trying to work around it
Bushes all done on the left.
ID:	28657   Click image for larger version
ID:	28658   Click image for larger version
ID:	28659   Click image for larger version
Old 13th June 2022, 06:25 AM
Morning challenge - who knows what this does?
