Old 5th August 2009, 06:40 PM
AndrewGray AndrewGray is offline
Default Subframe Mounts
The subframe has 4 bolts that go through the subframe bushes into what i believe are capitive nut in the chassis.
I'm wondering if the ones which sit under the footwells in the front of the car are accessible from inside the car?!
One of mine is spinning so I am unable to tighten the bolt properly
Old 12th August 2009, 03:49 PM
anyone?!
Old 12th August 2009, 05:06 PM
No idea mate... have you tried taking the carpet out to look for it?
Old 12th August 2009, 06:03 PM
Yeah, i'm down to a board of wood
Going to remove that tomorrow and see what is behind it
Old 12th August 2009, 07:46 PM
Is it on the bulkhead in front of the passenger's feet? Behind that are a batch of relays and power connectors Be careful, some big feeds there.
Old 13th August 2009, 07:59 AM
yeah it is and that isnt what i wanted to hear.
I need to get past all of that to check if there is a grommit or a way i can get through to the captive nut
Old 13th August 2009, 08:20 AM
Andrew,
As you probably know I took out my lump and box with the subframe and I could not see a way to get to the captive nuts. I will check later on Elsawin and EKTA and get back to you.
Old 13th August 2009, 09:16 AM
Sadly we concur - We know of no way to access the captive nuts that are effectively inside the box section.... Certainly there is no way from inside the cabin, so we can save you some time there....
Old 13th August 2009, 11:14 AM
Not what I wanted to hear but thanks anyway! ^^
