Help with brakes please
After having my new discs/pads/wheel sensor i have two small problems which i could doo with help....
My new pads seemed to squeal a week after having them fitted so i contacted the garage and they took it straight back in and ended up putting a new sett of pads in the front and even took the new ones in the rear out and checked them aswell..but when i collected it they couldnt get the brake disc/pad warning light off even after resetting it with the computer thingy........any ideas..??? as i got out of my car tonight i found two black springy wires thet i gather are the pad vibration clips lying next to my front wheels (one either side)............should i be worried......????? |
Yes. What model and year of 8 and which model of brakes please?
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
The springs are designed to keep pad movement to a minimum. If these are loose or missing the pads can move about, causing the squeling. This could also cause rapid wear of the mounting surfaces and pad faces - you don't want the pads breaking up!!!! Whre are you based??
