Old 5th April 2010, 05:18 PM
Mkoneman's Avatar
Mkoneman Mkoneman is offline
weird my old A8 had that relay fitted but didnt have servotronic
www.facebook.com/obdworks
full genuine ross-tech vcds
full genuine vag- tacho
Old 7th April 2010, 11:33 AM
Originally Posted by Ian@A8Parts View Post
Looks much better....
The rear airbags can be coded out I'm 99% sure as we've looked at this before, then the airbag module wont look for rear seat ignitors, and it wont flag up errors...
I can look in more detail for you, but wont be for a few days...
If you get chance to look on vagcom at what the softcoding is currently on the airbag module for your car it would help
Thanks Ian, I will do this soon.
Old 13th April 2010, 11:23 PM
Changed the front seatbelts today. The ones from the 95 car didn't fit, so two new black ones ordered from A8 Parts and were fitted today, tested and working perfect.
Next up, changed the airbag coding from 00225 to 00101. This coded out all the rear airbags and also the front occupancy sensors (handy if you have your air bag light on - common on some sport seats).
Only two fault codes now are the two front seat ignitors. These are going to be a little more tricky then just coding out with Vag Com but not impossible, I'll report back once I have worked out how I have worked them out.
Next up, a solar roof.
Old 13th April 2010, 11:30 PM
...and then there should be a different lower B pillar part as you will have boot release/alarm buttons on the 1998, but neither in 1996 I reckon...
Very true, the 95 only had an alarm button which is pointless to me. So I connected the boot release button up to it instead. I didn't even know I had this , would have come in bloomin' handy too in the S8 with my rear cam install
Old 14th April 2010, 06:53 AM
Hmmm.. Not sure what 00101 is, sounds very basic, but 00127 was the base code for the original 1994 cars with no side airbags or seatbelt pretensioners - Have you tried that ?
Old 14th April 2010, 11:00 AM
I have a feeling I did try 00127, but I don't think it coded out the front passenger occupancy sensors. Will code it as 00127 again and see what happens.
