Old 23rd May 2022, 07:02 PM
Default Discs and rear pads for my S8
Discs and pads, front and back, need replacing on my S8. I have bought the front pads (TRW) on MJ’s recommendation that they are a good fit for the Brembo calipers. The rear calipers are standard Lucas ones IIRC.
Does anyone have recommendations for the discs (front and rear) and rear pads?
Old 23rd May 2022, 07:10 PM
TRW rear pads tend to be branded as 'Cotec'. There are loads of options for rear discs as they're the same as the front of an A4 or Passat, but choices are very limited on front discs for the Brembos. I've found Febi are the best of the standard options, and are available front and rear.
Oh, they tend not to be easily available from motor factors since they aren't very popular. I buy them on ebay from either JD Motorsports or Parts in Motion, both of whom are excellent. I'll find the listings / part numbers in a bit.
Old 23rd May 2022, 07:17 PM
A reply in less than 8 minutes! Thanks MJ
Old 23rd May 2022, 08:44 PM
Links / part numbers would be very helpful indeed, thank you
Old 23rd May 2022, 09:01 PM
Parts In Motion:
Febi 44051 front discs 345mm
Febi 18398 rear discs 280mm
JD Motorsport:
TRW GDB1532 front pads
TRW GDB1330 rear pads
PIM sometimes have pads as well, but not when I bought the last set. Both of these sellers are highly recommended for the brands that we like, and are cheaper than pretty much anywhere else.
Old 23rd May 2022, 09:06 PM
Markiii Markiii is offline
Worth a look at ecp. I got pagid discs and brembo pads all round for 200. Sometimes their deals are crazy
Old 23rd May 2022, 09:21 PM
You are a star, MJ. Thanks so much, yet again!
Old 30th May 2022, 04:49 PM
Oops, both the links for pads are for front ones, so I’ve ordered two front sets - doh!
Are these the right ones for the rear: https://www.ebay.co.uk/itm/153169116...3ABFBMpu7826Jg
Old 30th May 2022, 05:33 PM
Oops sorry! JD Motorsports are pretty good for customer service but I've never tried returning anything. If for some reason they won't take them back let me know and I'll buy them from you
Those are the correct rears. I've fixed the link.
Old 30th May 2022, 06:17 PM
Thanks Michaela. i should have paid more attention as your part numbers were correct.
