Old 16th December 2015, 10:32 PM
Bushido Bushido is offline
Thanks all.
Ian , can you please elaborate? Hassle because of the physical swapping out or issues with the milometer discrepancy after the change?
Usually huffing, puffing and buffing in a dark corner somewhere...
Old 17th December 2015, 12:20 PM
Originally Posted by Bushido View Post
Thanks all.
I think from memory that the dash has the immobilizer coding in it so it is specific to the car and you'd be very advised not to try and swap to another dash!!!
Old 17th December 2015, 01:35 PM
Yup, assuming we're talking about a facelift D2 here, then the immobiliser for the engine ECU is built into the instrument cluster, so you will need the immobiliser recoding, which isn't a DIY job.
+ the mileage would then be out, and mileage correction on the FL D2 is a cluster out and attack with soldering iron job iirc.
To add insult to injury, even if you do send it off to be fixed, your car is then immobilised until the cluster is returned, or permanently if its lost in transit
So thats why most folk just live with it...
Old 19th December 2015, 05:30 PM
So just to be clear, what exactly are we saying here?!!
