Old 28th March 2014, 07:25 PM
I just had a eureka moment! I got the car with a cream interior with intention to change the interior to black, and was looking on German ebay for the most troublesome item, a black LHD dashboard. Now I realise I could just get it sprayed black with plastidip or some vinyl dye!
Just some quick research I did today into dyes:
VHT Vinyl dye
SEM Vinyl dye
http://forums.bimmerforums.com/forum...vinyl-dye-TIPS
http://forums.bimmerforums.com/forum...-SEM-Vinyl-Dye
http://www.clublexus.com/forums/sc-4...or-panels.html
http://forums.overclockers.co.uk/sho...php?p=24893576
http://www.civinfo.com/forum/styling...pe-s-trim.html
http://www.yourautotrim.com/semdye.html
Also, for the grab handles they are easy to repaint yourself with high quality Tamiya spray paints, they are synthetic lacquers and have a excellent finish.
I used Tamiya masking tape and a shopping bag to mask the wood effect trim.
This is from the S8 I sold.
The original vinyl covering will come off with some isopropyl alcohol and kitchen paper towels. I didnt bother sanding the hard plastic underneath.
Not perfect but much better than before
Name:	S8 trim handle before.jpg
ID:	7626   Click image for larger version
Name:	S8 trim handle after 1.jpg
ID:	7627   Click image for larger version
Name:	S8 trim handle after 2.jpg
Old 28th March 2014, 09:17 PM
Interesting post on the A2 forum
http://www.a2oc.net/forum/showthread...ontrol-Buttons
Old 31st March 2014, 07:09 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Nice job that man.
Audi did a repair paint for their soft touch.
hmmm that's interesting.
[center]
06 3.0TDI Quattro:
Options:
Old 6th April 2014, 09:37 AM
ToreBj ToreBj is offline
Lots of good info/alternatives here. I did mine before I saw the last posts here. As mentioned it is easy just to rub off the vinyl covering stuff leaving an even/smooth surface to repaint. I used a paint called Color Bond which I've also used with very good result on my lower B pillar trims and doorstep trims. See http://www.colorbondpaint.com/
As you can see this stuff can be used to completely change anything in the interior to another color.
Attached my result.
'99 A8 D2 2.5 TDI Quattro facelift
'02 A8 D2 W12 6.0 Quattro
Old 6th April 2014, 10:14 AM
Very interesting !
Old 6th April 2014, 11:38 AM
Interesting, you used colorbond, and the guy from this thread who says he has lots of experience recommends colorbond.
http://forums.bimmerforums.com/forum...dye-TIPS/page2
I ordered a can of SEM Satin Black from the UK.
I may try it on my rear view mirror, its hard to find one in black on German ebay.
http://www.nwsr.co.uk/searchResults.aspx
Old 6th April 2014, 09:32 PM
Default Masking
Goran, congratulations on what seems like a very good paint job result. I saw the picture on how you did the masking job and like to mention how I did mine. I used PlastiDip applying 2-3 coats and peeled away the lower part after cutting with a sharp knife in the crack. After the paint job was done I just peeled off the PlastiDip stuff.
My first attempt to repair was using PlastiDip only, but as others say it doesn't take much before it starts peeling if you're not careful. The result may be better if you make a mix of thinner and PlastiDip 1:1, certainly closer to the original touch and feel.
