Creaking noise front suspension
I have been reading into this for a bit, but can only find info about creaking suspension when cold.
Mine ('97 2.8 Sport) is quite the opposite - the hotter it gets, the louder it gets. To a stage where people actually look up to see where the sound comes from when I pass at 30mph I've had a little poke about a few days ago, but can't find any obvious play in any of the arms/bushes - except maybe the drop links were a little too easy to move. I sprayed every bush/joint with silicone spray and that cured the issue for about a day. Any ideas? |
Spraying them with some juice obviously stopped the creaking even if it was short so i'm going with old dry rubber bushes. Time for new arms?
1996 A8 4.2 QS. Bose, Solar roof, um...um... rally sport towbar. Now gone to a new home as the Traders 8. Bright yellow bus o love. |
I'm also leaning towards the ball joint of the track rod end. On full lock (left and right) there is no creaking at all |
You'll need a press to get them out and to be honest unless you have one and want to play and change them yourself it isn't really worth it. You can buy arms from loads of places, have a search on here in the suspension area.
I used ebay and had a full set for under £150 but £500 will buy Melye arms, second set since owning the car and i would think the last now. Depending how many free beans you have in your pocket at the time i suppose, i wouldn't change 1 or 2 you'll need a 4 way alignment everytime and could end up chasing the next arm.
I have found the noisy part. It's the lower arm. The one where the drop link is fitted to.
Copper greased moving parts and the noise was gone for about 30 minutes. I guess new arms are required. There is no play at all in the bush though and the rubber doesn't look bad or dry. I just hope new arms will cure the creak....... |
