Old 23rd May 2022, 06:45 PM
I bought the unit ages ago when I knew the original was degrading and none were available.
I also reckoned even D3 ones might not be around that long so made a "pre-emptive strike".
Oddly in recent times it's been less noisy, but when that happens you just know it's a matter of time.......
I'm sure it was on this forum that I discovered the units were identical apart from the connector.
Old 26th May 2022, 07:57 PM
Slowly going back together, a pic dump of a few things.
ID:	28529   Click image for larger version
ID:	28530   Click image for larger version
ID:	28531   Click image for larger version
ID:	28532   Click image for larger version
ID:	28533   Click image for larger version
ID:	28534   Click image for larger version
ID:	28535   Click image for larger version
ID:	28536   Click image for larger version
ID:	28537   Click image for larger version
Old 27th May 2022, 07:37 AM
Ronin Ronin is offline
that AC clutch is really like a small CC motorbike clutch
Old 27th May 2022, 07:28 PM
Except magnetic
Ready for the front panel to go on in the morning:
Apologies for the potato-cam picture quality. I dropped my phone recently and cracked the lens on the camera so its having trouble focusing
Old 28th May 2022, 07:36 PM
Front panel on
Filled with fluids and running again
The rear hubs are very rusty
Better
One of the handbrake cables is loose, which doesn't quite explain why the handbrake isn't working properly, but is probably having an impact
New Febi discs and TRW pads as per the front
The rear spring platforms cleaned up nicely
Springs back in place. I am planning on doing the rear bushes after it comes back from Nicola.
The centre wiper spindle is very badly worn, so much so that I can't even get it apart. I don't have a solution to this yet though so I just had to grease it thoroughly, along with all the other joints.
Back in the car - much easier with no bonnet!
ID:	28554   Click image for larger version
ID:	28555   Click image for larger version
ID:	28556   Click image for larger version
ID:	28557   Click image for larger version
ID:	28558   Click image for larger version
ID:	28559   Click image for larger version
ID:	28560   Click image for larger version
ID:	28561   Click image for larger version
ID:	28562   Click image for larger version
Old 28th May 2022, 09:31 PM
I'm guessing the bonnet will stay off until the windscreen is replaced on Monday?
According to an email I just got from Autoglass, that's happening between 1pm and 4pm.
(Though they apparently will send a text message on Sunday evening to say which 3 hour window in that time slot they will be arriving in! )
Old 28th May 2022, 10:01 PM
The bonnet is going on tomorrow as Marcel is coming over to help, and the bonnet is a 2-person job
Old 29th May 2022, 07:26 AM
Very common problem on Tesla's that spindle bushings wear out, so much so that wiper arm rubs on bonnet. I bought a cheap worn out mechanism on eBay and replaced old worn out steel bushes with bronze bushes. Spindle it self was not worn too bad plus I used longer 14mm bushes instead of original 10-11mm long so they cover unworn area on spindle. With original bushes there was about 6-7mm space in the middle between them and with replacements there is only about 1-1.5mm between them. Had to drill out opening in mechanism from 17mm to 18mm for replacement bushes.
This is what I used https://simplybearings.co.uk/shop/p2...duct_info.html
Old 29th May 2022, 07:31 AM
Its surprising modern cars are still having issues with this.
Unfortunately the D2 spindles tend to wear very badly as they are chrome plated, which wears / rusts off, and then the spindles go oval The D3 spindles appear to be hardened and are longer than the D2 ones so I'm hoping to be able to put D2 arms on D3 spindles, replace the bushings, and fit balljoint linkages. When I get time...
Old 29th May 2022, 07:34 AM
pete-p's Avatar
pete-p pete-p is offline
I'm curious about what type of screen you had and which Autoglass are replacing with. I've been waiting a while for them to contact me about my new screen, currently have heated and insulated so will lose the heating.
Cars...
