Old 25th April 2022, 02:36 PM
scottmgibb scottmgibb is offline
Mmmm... that does look good. I may indeed go with red
Audi S8 D2 2002
Old 14th August 2022, 05:02 PM
Default Brake Jud-d-d-e-r Here we go again.
OK, so the front calipers were refurb'd as described at the start of this thread 6 years ago. Over the last few months I havent been using the car that much but there was a hint of judder which, on my last motorway/fast outing recently started to get noticeable at high speed. So, as i had some new Brembo pads sitting on the shelf, I thought i would investigate whether the pistons/pads were sticking and renew the pads whilst i was at it. I did have real trouble getting the pads/ pistons retracted and then getting the pads out of the guides required considerable force. After removing the pads I was able to get the pistons fully depressed albeit with the aid of clamps but they did, eventually, move under finger pressure. It seemed to me that the pads sticking in the guides was the main issue. So, after some filing, i got the new pads to fit in the guides with just sufficient movement. Result - so i thought. Test drive employing a bedding technique involving a number of stops from 60 to 0 soon revealed alarming judder.
I should add that when the calipers were off the discs and pads removed I did carefully try the brake pedal without the engine running to see if the pistons would move out. (I used a chunk of wood of suitable thickness to ensure the pistons wouldn't pop out completely). There was very little movement 3-5mm at most and what there was different for each piston.
I don't subscribe to the "warped discs" theory after reading an authoritative article by some brake specialist and the suspension arms are all pretty recent so there should be no play there. The car had an alignment check 2 years ago. If it is sticky pistons why should this happen after 6 years?
I'm now thinking about getting them refurbed - again - though this time at BCS as they give a lifetime warrant as well as on the paint. (The previous powder coating has peeled off from 50 percent of the caliper's surfaces ). The alternative is a D3 upgrade but the lack of uprights is an issue and, besides, that's not a job i can do at home. Is there anything else i should try before sending the calipers off?
Old 15th August 2022, 11:48 AM
Snaggle57 Snaggle57 is offline
Mine had brake judder and new discs and pads made it even worse. I ended up having the discs skimmed whilst on the car and it’s never returned since (97 s8)
97 S8
97 A4 2.8Q
05 A6 1.9tdi
89 VW Caddy GTI
Old 15th August 2022, 12:46 PM
Thanks for that suggestion. I have cleaned the mating faces of the discs and hubs so they are sitting true but i realise that still wont ensure that the discs are running true.
Old 15th August 2022, 05:34 PM
Mine got worse the hotter the brakes got, to a point where it was quite violently shaking the steering wheel after a spirited drive. Did this on 2 different sets of discs and pads. I heard the hubs can be ever so slightly out but not sure how true that is? Skimming them certainly solved the problem though, it was a long time ago but think it was about £60 a side
97 S8
97 A4 2.8Q
05 A6 1.9tdi
89 VW Caddy GTI
Old 15th August 2022, 06:13 PM
It certainly got worse the hotter the brakes got under fierce braking. There doesn't seem to be any run-out on the hubs but I guess that's hard to judge using eye and hand alone.
Undid the brake lines from the calipers to enable complete removal this pm. Ran into the problem of the securing nut stuck to the pipe which meant that i was twisting the pipes. Used MJ's tip in another thread of unscrewing the caliper from the line and then heating the nut to "unstick" the nut from the plastic coated brake line. Thanks MJ
