#181
Had to plonk this in Google Translate...
"Cleaned up the sump and the magnets" Translated to: "Part returned to OEM/factory/showroom A1 condition"
#182
Literally the only thing anyone ever got right on this car
The only original parts left of the powertrain are the flywheel and, ironically, the F125 Kersteman's final bodge, fitting a used switch which was equally as broken as the original, is actually what saved the car from certain death. I forgot to take any more photos, but the engine and box are now joined together again, fluids filled, and oil system primed. I'll clean up the subframe tomorrow and mount the engine and box back on it, and then I can move on to the engine bay. |
#183
Started scraping the detritus off the subframe - it was half an inch deep in places! Didn't have much time tonight so I'll get some elbow grease on this tomorrow.
#184
Once you’ve finished with your Murple not only will it be running better than ever, but I suspect there will be a fair bit of weight saving too based on the crud removed from the subframe
2002 S8 - Irish Green Pearl. Cat N (saved by the D2 Doctor ) 1988 E30 Coupe - Royalblau Metallic 2003 S4 Avant - Light Silver Mettalic 2016 S5 Coupe Black Edition - Ibis White |
#185
Progress was slowed a tad this week when this monster tree feel down and killed my speedboat Luckily the Polo V8 survived relatively unscathed - a few dents and scratches in the completely ruined paint, but the glass was untouched. When we started, you couldn't even see the Polo! It took 2 days to clear this back as far as the retaining wall.
I cleaned the subframe with Elbow Grease and the pressure washer. Its in great condition, barring the dents and bruises underneath where someone has used it as a jacking point. No holes though. I might paint the rusty bits. On to the engine bay. What new horrors am I going to find in here...? Fairly nasty heat shields. Not sure how an aluminium part appears to be rusty Many studs snapped off. Replacement stud-rivet things are actually available for these (which I didn't know when I did my grey S8), but the damn things are £12 each!! There are 5 snapped off The bay is pretty nasty The rack is covered in oil, but this is engine oil from the cam covers The fuel pipe clips are rusted through. There should be a set of these coming on back-order, hopefully. An oily mess in the tunnel too The PS pipes are in amazingly good condition considering how knackered the rest of the car is. I suspect they may have been changed at some point. Still got a bunch of snapped rivnuts to deal with With heat, WD40 and vise grips, the broken front panel bolt eventually came free Then I could remove the nut for the towing eye This is in a right state Separated the two parts. The steel bits will go in the Evaporust tub for a while, and the bracket will get blasted and painted. |
#186
This is why I suspect the PS pipes may have been replaced - the bracket is broken and bodged
The top rubber mount has been replaced by a nut and bolt, and the bottom one is torn off. This is going to be a right pain to remove as there's nothing to grip. Taking the heat shields off, I'm cutting the nuts to save the studs, since the nuts are only 67p and the studs are £12. Had to remove the electronics box to get the AC pipes out as all the unions are seized The whole lot came out in one go. I'll separate these in the vice where I can use heat and more force. The aim is to save the pipes at the expense of the consumable parts - condenser, evaporator etc. I forgot to disconnect the steering column before I put the car on the lift, so I lowered it on to the pallet truck and pulled it forward so I could open the door. With the column disconnected I could remove the steering rack. Well, there's the problem with the servotronic. The insulation on the wires is brittle and disintegrates on contact Crusty... Hard to get a picture, but there is a dent in the right hand chassis leg which I suspect was from changing the oil pressure switch. Passenger side scrubs up ok under all the grot. |
#187
That sounds intriguing. Any info about it posted on here to read?
Would you have expected anything less from this car?
#188
In the current lockdown the thing that differentiates the weekends from every other day is the Murple/WITW updates
With all the issues you have with this car, its nice to see that the engine bay is lacquered. At least that is some reward for using the ton of degreaser!
2002 D2 S8 – Ming Blue, Valcona leather, Vavona wood insert, solar sunroof (to be fitted), Heated rear seats, extended leather pack, 18” Avus, ski hatch, Bose, auto dim rear view mirror, rear blind. Last edited by David's8; 31st January 2021 at 08:23 AM. |
#189
Its a 'when I have time' project I was thinking exactly that as I wrote it FL1 Its a delicate balance between cleaning it but not scratching the lacquer. At least in an FL2 there's less risk of scratches, but then the end result isn't as pretty. |
#190
The more I see pictures of the purple, the more I like it.
-Andrew 1967 Bus 1980 Rabbit Pickup 1992 Corrado 2001 S8 2010 Jetta TDI Cup Edition |
