Old 31st January 2021, 02:21 PM
Before and after
My potion of choice - Gtechniq W5 All Purpose Cleaner, and a soft brush. This gets most of the dirt off and is just rinsed off with water. I use brake cleaner for the real heavy grease and oil (mostly on the other side), and I'm now also using Elbow Grease for lighter oily dirt. Elbow Grease is ok on heavy stuff if you use a stiff brush, but on paint I prefer to use the brake cleaner as it just dissolves it with much less effort and reduces the risk of scratches.
After the various cleaning solutions, I blow it dry with compressed air, then go over with quick detailer to pick up the last of the smears.
Almost there now. I need to deal with the snapped fasteners, and clean out the wheel arches, then I'll go over the whole lot with sealant to make it hydrophobic.
ID:	25375   Click image for larger version
ID:	25376   Click image for larger version
ID:	25377   Click image for larger version
Old 31st January 2021, 03:24 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Originally Posted by Stromaluski View Post
The more I see pictures of the purple, the more I like it.
Murple is lush . I turned one down several years ago and have regretted it ever since. I could of had it for less than £2k as well
Good job as always MJ. The before and after are like night and day. Seems a shame to put the engine back in as no one can see all the lovely shiny-ness afterwards
2016 S5 Coupe Black Edition - Ibis White
Old 31st January 2021, 06:46 PM
Audifan Audifan is offline
Wow MJ, you do amazing work!
Old 31st January 2021, 07:49 PM
Thank you
Well, its still throwing up surprises I was going to clean the rain tray on the right hand side when...
I discovered a hole in the underseal right in the corner. Poke poke poke, and there's a section about 2x3" where the underseal is loose and just falling off in chunks.
After some cleaning with solvent and a wire brush, its basically bare metal and exposed seams. Water will have been getting in here since all the drains were blocked, but its been in the workshop for a year so nice and dry now
Obviously I had to go and poke the other side I completely missed this when I was doing Botang's hole
It came off in one huge chunk on this side - just spooged in there and not bonded at all, with dirt behind it.
I cleaned both sides as thoroughly as possible with solvents (nothing water-based), then applied new seam sealer. I will wait for this to completely dry before cleaning this area any more.
Started on the wheel arches. Cleaned with APC, then hit it with W7 Tar and Glue remover to dissolve all the tar spots.
This stuff is great - spray on and the tar just melts away
Second pass and its almost all gone
If you're not standing in your wheel wells to get the tar off the wheel arch lips, is it even detailing?
Driver's side nice and clean now
The rack has definitely been out at some point. Remember the stupid-expensive rivets I mentioned earlier? This is one, used to replace a snapped body stud which gets in the way of getting the rack out. Its pretty much guaranteed that the butcher of Bristol didn't fit this (he would have used a self tapper) so I think this was done before it was 7 years old while it was still being maintained by Audi. The rack isn't a re-con and I have no receipt for the work so its unclear what was done, but it may explain why the hoses appear in much better condition than normal. Note - I bent it getting the rack out but it straightened out ok
Passenger side done. Interestingly, just like Big Red, the chassis leg is lacquered on the left and not on the right!
Does anyone know what this is and where it goes?
ID:	25384   Click image for larger version
ID:	25385   Click image for larger version
ID:	25386   Click image for larger version
ID:	25387   Click image for larger version
ID:	25388   Click image for larger version
ID:	25389   Click image for larger version
ID:	25390   Click image for larger version
ID:	25391   Click image for larger version
ID:	25392   Click image for larger version
ID:	25394   Click image for larger version
ID:	25395   Click image for larger version
ID:	25396   Click image for larger version
ID:	25397   Click image for larger version
ID:	25398   Click image for larger version
ID:	25399   Click image for larger version
ID:	25400   Click image for larger version
ID:	25401   Click image for larger version
Old 31st January 2021, 08:44 PM
I assume that you know, MJ, and this is a teaser. Because if you really don’t know, what chance have we mortals?
Old 1st February 2021, 08:07 AM
Yes, I know what it is
Old 1st February 2021, 09:33 AM
I'd guess it's a seal or anti-vibration device of some sort, but the real mystery is why the four conical plug shapes?
Old 1st February 2021, 12:40 PM
Is it something to do with the radiator?
MJ, having cheated to find out what it is, you need to give us mortals easier ones to give us any chance of knowing.
A suggestion for you for when you finish the car. Post a photo of the one single item you didn't have to fix!
Old 1st February 2021, 01:16 PM
Hmm. Thats going to be tricky...
I'm intrigued how you found out what it is without a part number?
