Go Back   A8 Parts Forum > A8 D2 > D2 - Common Faults
D2 - Common Faults Quick links to all known common faults and their solutions
Old 16th February 2021, 09:49 AM
Default Boot Lock Failure - Removal and Repair
The following instructions on the repair of the boot lid locking mechanism is the work of Michaela/MikkiJayne/D2 Doctor and is a single post extract from one of her threads. I've posted it as a separate thread to make it easier to find.
Also fixed the boot lock since it was seized completely solid
Removed via the door for for the light cluster
Disassembled the main body
The lock barrel was completely seized in the housing. Lots of WD40 and wiggling and it finally came free.
Crusty!
Started removing the tumblers
All disassembled. It took about half an hour cleaning schmutz out of the barrel with an assortment of pokey tools, degreaser and compressed air before the little door would close again!
Cleaned all the tumblers up
Reassembled prior to re-greasing
Going back together
You can see the cam which operates the central locking here via these two microswitches
All back together and ready to put back in
Old 16th February 2021, 10:02 AM
Thanks Sean
Refreshing my memory on how this goes together, I think the key just spinning may be caused by the tab on the end of the lock barrel not being engaged properly in the rest of the mechanism. Given that this whole thing is mostly lightweight pot-metal it could be that one or more pieces are actually broken, but if that is the case then either the barrel, or the individual tumblers could be swapped in to a used lock mechanism to resolve the problem while keeping the same key.
If anyone wants to remove a spinning lock and send it down for diagnosis / repair then let me know
Old 21st February 2021, 09:56 PM
I've been having a look at David's lock over the weekend. Everything seemed in good order and nicely greased, but the barrel was stuck fast in the surround. After sitting overnight in WD40 I managed to get it apart and discovered that it was just corrosion on the first few mm of the barrel holding it place.
After cleaning, it was clear why - the rubber seal was perished and disintegrated so moisture could get in.
The seal is a flat-ish moulded thing which is not available as a spare part. The thought occurred that an o-ring might work to replace it, and the oil cooler pipe o-ring appears to be just the right size
It actually goes together quite well, but its a little stiff to turn so it might need a smaller o-ring.
Or, I might see if I can print a polyurethane replacement for the original seal.
ID:	25636   Click image for larger version
ID:	25637   Click image for larger version
ID:	25638   Click image for larger version
Old 22nd February 2021, 10:49 AM
Mine doesn’t have a seal there at all, and the barrel was corroded at the top end like David’s. I’ve got a load of different sized O-rings, so I’ll pop one in when I fit the last tumbler. Good job you pointed that out, otherwise I expect mine would have corroded again in no time!
Old 22nd February 2021, 11:09 AM
I'm about to try printing one. If it works, I'll post you one with the tiny spring which will be on its way this afternoon
Old 22nd February 2021, 12:11 PM
The printed part is perfect for the job will post a pic later
Old 22nd February 2021, 12:28 PM
You’re a star! Thanks Michaela
Old 23rd February 2021, 08:30 AM
Printed seal in place:
Old 23rd February 2021, 08:37 AM
Thanks MJ,
Neat job .... and now youve shamed me with the state of the key (its lost the audi rings and generally looks old and battered like its owner), im going to have to get a new key!!
Old 23rd February 2021, 08:56 AM
HPsauce HPsauce is online now
The solution is cheap as chips for missing rings.... http://forum.a8parts.co.uk/showthread.php?t=15821
