Ticking noice at 1800-2000rpm
Hi.
I have a ticking noice at ca 1800-2000 rpm, the noice is coming when i run on flat ground and have almost no throttle. Also downhill with zero throttle, braking on the gears. Under acceleration,slow and fast i cant hear anything. Took an comression test all ok, and took of the valve cover, and on the bank 1 syl 1-4 the chain tensioner had a worn groove from the chain and oil around it,outside cover. Can that be a broken tensioner causing the ticking sound? Cant hear anything with a stethoscope on the engine. Hav no fault code on VCDS. Just changed oil, no difference. Its the AQH engine. Or does anybody have another solution on my problem? |
Hello, could you record a audio clip of the ticking noise please?
These are noisy engines, injectors clicking, active charcoal filter should always be making a ticking/clicking noise also. Chain tensioner going bad usually results in a loud rattling sound. I would definitely replace those pads before they fail. |
I will try to make a audio clip tomorrow
Tried to make a soundclip but cound not hear anyting on the clip, due to the exhaust noise
Must be some good exhaust
Exhaust is good, hehe
It was hard to get it done alone, and no time before i went to work offshore. Can try again when i come home with some help |
