Old 8th August 2014, 04:42 PM
Should have been to Specsavers?
What device are you using to view, it's just partly behind the caliper?
Old 8th August 2014, 04:54 PM
Ironically, I picked up my new glasses last night from said specialist....
I think I need a refund....
Old 8th August 2014, 07:16 PM
You can code the ABS module currently on the car if you wish however it is a straight swap exactly the same as the RS6 brake set up. infact I think david at A8 parts did the RS6 6 pot mod on the W12 and its a bolt on set up only the Ceramics are much better and a bit larger
This Kit includes the Following
Front discs (Pair )
Front calipers and carriers
Front Pads
Rear Discs and Pads
rear Callipers and Carriers
Its a full set of 4 brakes at that price
I will upload some more pictures asap
Old 9th August 2014, 12:37 PM
Bargain.
Old 25th August 2014, 03:11 PM
Sfs
Old 16th September 2014, 08:33 PM
A8 Doc A8 Doc is offline
Any idea if these fit a C7 RS6?
Old 17th September 2014, 06:46 AM
Well the C7 RS6 brakes fitted to davids W12 would indicate they should fit an RS6 i would have thought they swap both ways i would be inclined to say yes
Old 17th September 2014, 11:10 AM
They were C6 RS6 brakes.....
Old 17th September 2014, 11:37 PM
kal_ay's Avatar
kal_ay kal_ay is offline
So tempting
2002 D2 S8 Misano Red
1996 Volvo 850R Estate Red
2013 Mercedes C63 AMG (taxi)
1991 Lotus Carlton Imperial Green
Old 18th September 2014, 10:11 AM
Ahhh C6 brakes in that case i have no idea about a C7
