Old 17th June 2014, 01:28 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default Capped nuts spinning
With the front bumper off I thought I'd take my lights out and do something bits and I wanted to do.
I was able to remove some of the bolts but noticed that a couple of the nuts that's pressed in to the front slam panel are just spinning.
I can get them out with the help of some mole grips but I need to replace the capped nuts.
Anyone know how to replace them with out breaking the panel?
[center]
06 3.0TDI Quattro:
Options:
Old 17th June 2014, 05:05 PM
Pictures Scott as there is many types.
Old 17th June 2014, 05:12 PM
ScottD3's Avatar
The bumpers back on now lol.
I'll see what I can get.
[center]
06 3.0TDI Quattro:
Options:
Old 20th June 2014, 08:09 AM
ScottD3's Avatar
I tried, I can't get near the spinning nuts without taking the bumper off again.
[center]
06 3.0TDI Quattro:
Options:
Old 9th July 2014, 07:44 AM
Can you just JB Weld the existing ones to stop them spinning?
Old 9th July 2014, 09:11 AM
ScottD3's Avatar
Not sure.
They are hard to into.
Next time the bumper is off and I have more time I will give it another go.
[center]
06 3.0TDI Quattro:
Options:
Old 9th July 2014, 01:18 PM
ScottD3's Avatar
They are called Rivnuts.
More info to be shared soon.
EDIT: Removal.
http://electricalequipment.tpub.com/...-207-14_34.htm
[center]
06 3.0TDI Quattro:
Options:
Old 10th July 2014, 11:10 AM
andycaca andycaca is offline
rivnuts can be a bit of a pain to fit if you havent got the right tool to prevent it spinning. its possible to fit them with a couple of nuts on a bolt to provide the right tension, but if you stop tightening a little early you will be left once more with a spinning rivnut!
it might be worth your while either practising on a bit of scrap or buying/renting the correct tool.
Old 10th July 2014, 11:28 AM
ScottD3's Avatar
Been watching youtube videos and it seems straight forward enough when they are doing it on the bench and not in a engine bay.
Chatting to a friend the other night about them and he said they use to use them work and they might still have the tool to fit them.
He's going to have a look for me. If he has I'll pop over, strip the front end and replace them.
[center]
06 3.0TDI Quattro:
Options:
